Getting multiple security scan issues.
What is the latest version of httpd supported?
HTTPD version supported?
Re: HTTPD version supported?
Apache 2.2, 2.4
PHP 5.3, 5.4, 5.5, 5.6
It is worth pointing out that patches for vulnerabilities are fixed and back-ported in the repositories for the OS.
running the following will update to all latest patches
This will install all patches provided by the package maintainers, but will not change a scanner that is just looking at the package version as these are backported fixes.
yum update -y
