Backup / Maintenance
WillemDH
Post by WillemDH »
Configured backup / maintenance today. So I set 'delete indexes older then 30 days', I was wondering when exactly is the job to clean up these indexes running? Would this mean all data older then 30 days is purged. Is there some way to force the job which would delete the indexes older then 30 days?
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
Re: Backup / Maintenance
WillemDH wrote:Configured backup / maintenance today. So I set 'delete indexes older then 30 days', I was wondering when exactly is the job to clean up these indexes running?
It is the backup_maintenance job found under Administration -> Command Subsystem
WillemDH wrote:Would this mean all data older then 30 days is purged.
Yes, except if you have created snapshots in a repository, the snapshots would still be able to revive your data.
WillemDH wrote:Is there some way to force the job which would delete the indexes older then 30 days?
You can force the backup_maintenance job from Administration -> Command Subsystem by clicking Edit
Click in the Next Run Time field
Click now button
Click Update
One thing to note, if your Job ID's are just a bunch of scrambled chars, click the Reset All Jobs and they will get proper names..
WillemDH
Post by WillemDH »
Scott,
I confirmed the cleanup jobs etc are runnign fine. This thread can be closed.
Grtz
Willem
Nagios XI 5.8.1
