This support forum board is for support questions relating to
Nagios Log Server , our solution for managing and monitoring critical log data.
NMFSTeam
Posts: 88 Joined: Thu Nov 12, 2015 9:01 am
Post
by NMFSTeam » Fri Jan 21, 2022 2:48 pm
We are using the manual install directions provided by Nagios to install the Log Server onto an Ubuntu 20.04 instance, and getting an error immediately.
root@hqnaglogi1:/tmp/nagioslogserver# ls
CHANGELOG.txt fullinstall libinstall.sh mibs sourceguardian upgrade
addnode get-pip.py licenses nagioslogserver subcomponents
root@hqnaglogi1:/tmp/nagioslogserver# ./fullinstall
-bash: ./fullinstall: Permission denied
Any help you can provide would be most appreciated.
Thank you!
gsmith
Posts: 1253 Joined: Tue Mar 02, 2021 11:15 am
Post
by gsmith » Sun Jan 23, 2022 6:30 pm
Hi
Your /tmp directory is probably mounted with the "noexec" option. Take a look at
/etc/fstab to verify this.
You can try:
mount -o remount, exec /tmp
Run ./fullinstall
Then change it back:
mount -o remount, noexec /tmp
Please let me know how you make out.
Thanks!
NMFSTeam
Post
by NMFSTeam » Mon Jan 24, 2022 11:45 am
Actually, the server was deployed with just one mount point, / .
root@hqnaglogi1:~# cat /etc/fstab
LABEL=cloudimg-rootfs / ext4 defaults 0 1
LABEL=UEFI /boot/efi vfat umask=0077 0 1
tmpfs /dev/shm tmpfs defaults,nodev,nosuid,noexec 0 0
/dev/nagioslogserver/lvnagioslogserver /usr/local/nagioslogserver ext4 defaults 0 0
gsmith
Post
by gsmith » Mon Jan 24, 2022 11:52 am
Hi
There's the culprit:
Please change it to:
tmpfs /dev/shm tmpfs defaults 0 0
Then bounce the server. Run the ./fullinstall. Then you can change /etc/fstab back
to:
NMFSTeam
Post
by NMFSTeam » Mon Jan 24, 2022 1:56 pm
Still no go.
root@hqnaglogi1:/tmp/nagioslogserver# df -h
/dev/root 243G 4.6G 238G 2% /
devtmpfs 3.9G 0 3.9G 0% /dev
tmpfs 3.9G 0 3.9G 0% /dev/shm
tmpfs 796M 1.1M 795M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
tmpfs 1.0G 450M 575M 44% /tmp
/dev/loop0 9.2M 9.2M 0 100% /snap/canonical-livepatch/126
/dev/loop1 100M 100M 0 100% /snap/core/11993
/dev/loop2 56M 56M 0 100% /snap/core18/2253
/dev/loop3 56M 56M 0 100% /snap/core18/2284
/dev/loop4 62M 62M 0 100% /snap/core20/1242
/dev/loop5 62M 62M 0 100% /snap/core20/1270
/dev/loop6 252M 252M 0 100% /snap/google-cloud-sdk/207
/dev/loop7 253M 253M 0 100% /snap/google-cloud-sdk/216
/dev/mapper/nagioslogserver-lvnagioslogserver 1007G 77M 956G 1% /usr/local/nagioslogserver
/dev/loop9 44M 44M 0 100% /snap/snapd/14549
/dev/loop8 44M 44M 0 100% /snap/snapd/14295
/dev/sda15 105M 5.2M 100M 5% /boot/efi
/dev/loop10 68M 68M 0 100% /snap/lxd/21835
tmpfs 796M 0 796M 0% /run/user/1415284939
root@hqnaglogi1:/tmp/nagioslogserver# cat /etc/fstab
#tmpfs /dev/shm tmpfs defaults,nodev,nosuid,noexec 0 0
root@hqnaglogi1:/tmp/nagioslogserver# ls -al
total 1400
drwxr-xr-x 7 root root 260 Dec 7 18:59 .
drwxrwxrwt 14 root root 300 Jan 24 18:48 ..
-rw-r--r-- 1 root root 31828 Dec 7 18:58 CHANGELOG.txt
-rwxr-xr-x 1 root root 33 Dec 7 18:58 addnode
-rwxr-xr-x 1 root root 12251 Dec 7 18:58 fullinstall
-rwxr-xr-x 1 root root 1340902 Dec 7 18:58 get-pip.py
-rwxr-xr-x 1 root root 23855 Dec 7 18:58 libinstall.sh
drwxr-xr-x 2 root root 100 Dec 7 18:58 licenses
drwxr-xr-x 2 root root 80 Dec 7 18:58 mibs
drwxr-xr-x 3 root root 220 Dec 7 18:58 nagioslogserver
drwxr-xr-x 2 root root 80 Dec 7 18:59 sourceguardian
drwxr-xr-x 7 root root 140 Dec 7 18:58 subcomponents
-rwxr-xr-x 1 root root 13493 Dec 7 18:58 upgrade
gsmith
Post
by gsmith » Mon Jan 24, 2022 3:09 pm
Hi
Please send the output of these:
NMFSTeam
Post
by NMFSTeam » Mon Jan 24, 2022 3:52 pm
Here you go:
root@hqnaglogi1:/tmp# ls -l /tmp
total 219744
drwxr-xr-x 7 root root 260 Dec 7 18:59 nagioslogserver
-rw-r----- 1 root root 225015847 Dec 9 18:50 nagioslogserver-latest.tar.gz
drwx------ 3 root root 60 Jan 24 18:41 snap.canonical-livepatch
drwx------ 3 root root 60 Jan 24 18:41 snap.lxd
drwx------ 2 michael_blower_noaa_gov michael_blower_noaa_gov 60 Jan 24 20:50 ssh-KBAgPRSWFK
drwx------ 3 root root 60 Jan 24 18:41 systemd-private-01a9356d4d3c402cbb5e6e1cd985f732-chrony.service-NpZJFf
drwx------ 3 root root 60 Jan 24 18:41 systemd-private-01a9356d4d3c402cbb5e6e1cd985f732-systemd-logind.service-e1kBph
drwx------ 3 root root 60 Jan 24 18:41 systemd-private-01a9356d4d3c402cbb5e6e1cd985f732-systemd-resolved.service-9Iwaej
root@hqnaglogi1:/tmp# sestatus
Command 'sestatus' not found, but can be installed with:
apt install policycoreutils
gsmith
Post
by gsmith » Mon Jan 24, 2022 4:11 pm
Hi
That looks good!
Please send the output of:
ls -l /tmp/nagioslogserver
In /tmp/nagioslogserver please create a file called extest.sh with these contents:
Then run the following:
chmod 755 extest.sh
./extest.sh
And let me know the result.
Thanks!
NMFSTeam
Post
by NMFSTeam » Mon Jan 24, 2022 4:27 pm
No go, very odd.
root@hqnaglogi1:/tmp# ls -l /tmp/nagioslogserver
total 1400
root@hqnaglogi1:/tmp# vi extest.sh
root@hqnaglogi1:/tmp# chmod 755 extest.sh
root@hqnaglogi1:/tmp# ./extest.sh
-bash: ./extest.sh: Permission denied
root@hqnaglogi1:/tmp# cat extest.sh
#!/bin/sh
echo 'testing 123 '
gsmith
Post
by gsmith » Mon Jan 24, 2022 6:05 pm
Wow.
Is there any server automation (Puppet, Chef Ansible, etc) being used with this servers? If so
please run the following and send me the results:
mount | grep noexec
Please try this:
mktemp -d -tmpdir=/ (this will result in a file like /tmp.K6nLmbpk1n being created)
chmod 1777 /tmp.K6nLmbpk1n
cp -Rp /tmp/nagioslogserver /tmp.K6nLmbpk1n
cd /tmp.K6nLmbpk1n/nagioslogserver
./fullinstall
Let me know what happens
