COMMAND
check_file_size_age!-C 'ls -l /home/nagios/procmail.log' -F '/home/nagios/procmail.log' -T 'files'! -s 40960000,46080000
You must specify files to check on with '-F'
Usage: /usr/local/nagios/libexec/folder_watch.pl [-v] [-t <timeout>] -D <directory> -F <files to check> -w <warn level(s)> -c <crit level(s)> [-a [<warn age>,<crit age>]] [-s [<warn size>,<crit size>]] [-S [<warn size>,<crit size>]] [-f] [-r] [-l] [-T files
The exact same command works fine on our development server. Both servers running CentOS Linux release 7.9.2009 (Core) and Nagios 5.10.0.
This command, which is similar to what Nagios is trying to run, works at the command line of both servers:
/usr/local/nagios/libexec/folder_watch.pl -C 'ls -l /home/nagios/procmail.log' -F '/home/nagios/procmail.log' -s 40960000,46080000
OK - Largest size file is 1441910 bytes, 1 /home/nagios/procmail.log files found
Steve
