nrdp objects not in Unconfigured Objects
grenley
Post by grenley »
We're starting to build our production test environment and have a new XI server.
Our checks are all passive.
They're sending through nrds but nothing is showing up in "Unconfigured Objects".
Here's the XML transaction data that indicates XI successfully processed the data (from the remote nrds agent)
<?xml version='1.0'?>
<checkresults>
<checkresult type='service' checktype='1'>
<hostname>mytest1.att.com</hostname>
<servicename>Proc_PLATMON-cron</servicename>
<state>0</state>
<output><![CDATA[PROCESS OK - no errors found]]></output>
</checkresult>
</checkresults>
1
200 OK
<?xml version="1.0" encoding="utf-8"?>
<result>
  <status>0</status>
  <message>OK</message>
    <meta>
       <output>1 checks processed.</output>
    </meta>
</result>
We've never had this issue with our dev XI servers, so it must be something we missed in the XI configuration.
Rick
Re: nrdp objects not in Unconfigured Objects
Post by Box293 »
Just checking some basics, have you configured the NRDP Token in XI?
Admin > Check Transfers > Inbound Transfers
NRDP tab
Try a test from the NRDP webpage:
[url]http://nagiosxi_ip/nrdp/[/url]
When you do this, what is logged in:
/usr/local/nagios/var/nagios.log
grenley
Post by grenley »
The tokens match.
Besides, if they didn't, you'd get this:
200 OK
<result>
  <status>-1</status>
  <message>BAD TOKEN</message>
</result>
I submitted the sample xml (using the proper token) on the http://nagiosxi_ip/nrdp/ page and it returned this:
<result>
  <status>0</status>
  <meta>
    <output>2 checks processed.</output>
  </meta>
</result>
But nothing was written to nagios.log
Let's check one thing - go to Admin->Performance Settings->Subsystem tab and see if the "Enable Listener For Unconfigured Objects" check-box is selected.
grenley
Post by grenley »
yes. "Enable Listener For Unconfigured Objects" is checked
abrist
Red Shirt
Post by abrist »
Is the feedproc cron running on the XI server?
ps -ef |grep feedproc
If so, are you getting any errors when tailing this log (when receiving checks through nrdp):
tail -f /usr/local/nagiosxi/var/feedproc.log
grenley
Post by grenley »
yes, it's running.
and yes, we are getting php errors...
PROCESSED 0 COMMANDS
tail: /usr/local/nagiosxi/var/feedproc.log: file truncated
PHP Warning:  PHP Startup: Unable to load dynamic library '//opt/app/php/lib64/php/modules/curl.so' - //opt/app/php/lib64/php/modul0
PHP Warning:  PHP Startup: Unable to load dynamic library '//opt/app/php/lib64/php/modules/fileinfo.so' - //opt/app/php/lib64/php/m0
PHP Warning:  PHP Startup: Unable to load dynamic library '//opt/app/php/lib64/php/modules/json.so' - //opt/app/php/lib64/php/modul0
PHP Warning:  PHP Startup: Unable to load dynamic library '//opt/app/php/lib64/php/modules/phar.so' - //opt/app/php/lib64/php/modul0
PHP Warning:  PHP Startup: Unable to load dynamic library '//opt/app/php/lib64/php/modules/zip.so' - //opt/app/php/lib64/php/module0
abrist
Red Shirt
Post by abrist »
What is the output of:
cat /etc/php.d/mcrypt.ini
yum list installed | grep php
Also, what OS and version is this server?
Is it a clean, minimal CentOS/RHEL install? It almost looks like a non-standard PHP installation is present.
grenley
Post by grenley »
; Enable mcrypt extension module
extension=mcrypt.so
php-common.x86_64                 5.3.3-40.el6_6           @prod-x86_64-server-6
php-ldap.x86_64                   5.3.3-40.el6_6           @prod-x86_64-server-6
It's RHEL:
uname -r
2.6.32-504.8.1.el6.x86_64
