Nagios IP
kujo34
Nagios IP
Post by kujo34 »
Hi all,
at the first sry for asking. im new in the nagios community and don"t know much about it.
so i installed nagios xi on centos 6.8 and get a problem that i dont get ip address in nagios..
i tried some of fixed but without any success.
used "system-config-network" and setted fix ip but no success
please help who can i fix it to get to the console of nagios...
Reason: Moved from Ideas to Nagios XI - Please post in the correct section of the forum.
Re: Nagios IP
Post by mcapra »
From the Nagios XI machine, can you share the outputs of:
ip addr
find /etc/sysconfig/network-scripts/ifcfg-* -type f -print -exec cat {} \;
kujo34
Re: Nagios IP
Post by kujo34 »
show attachment
jomann
Development Lead
Re: Nagios IP
Post by jomann »
Can you take a look to make sure your udev rules have been replaced? There's an issue with cloning CentOS 6 boxes where /etc/udev/rules.d/70-persistent-net.rules tends to cause problems with interfaces coming up. It is supposed to have a fix on our VMs that we build but I am fairly certain that is the issue. More information here for steps to resolve.
