Hi Support,
i add the LInux OS on Nagios XI but the OID is not available
please assist me
Add Linux With SNMP Error
Re: Add Linux With SNMP Error
Hi @tsabit,
Before you can monitor a Linux machine using SNMP, you'll need to install and configure it on your linux machine.
On RHEL / CentOS systems use the following command:
On Debian / Ubuntu based systems use the following command:
Please follow this guide...https://assets.nagios.com/downloads/nag ... 1493223405 and then when you complete all the steps you may now use the wizard.
yum install net-snmp
sudo apt-get install snmpd libsnmp-dev
Hi dwasswa,dwasswa wrote:Hi @tsabit,
On RHEL / CentOS systems use the following command:On Debian / Ubuntu based systems use the following command:Code: Select all
Please follow this guide...https://assets.nagios.com/downloads/nag ... 1493223405 and then when you complete all the steps you may now use the wizard.Code: Select all
I have installed net-snmp on the server the communitity is "tmli" but still error on Nagios.
please assist me.
Regards,
Tsabit
Can you run the following from the CLI on your Nagios XI box and get a response that is not a Timeout?
If you do not, either the firewall is blocking access, the snmpd service isn't running or there is some other error in accessing the machine.
snmpwalk -v 2c -c tmli 192.168.1.84
Hi @tsabit,
First,can you please verify the version of linux you are using?
Second, please make sure that the snmp daemon is running by running by doing the following:
1.Go to your terminal on the remote / target linux host and run the following commnads:
Start the service....
Check if its running.....
expected output if its running:
Third,make sure ports for SNMP AND for SNMP traps are open. This you have to check on your firewall permissions.
OR
You could simply run to show you open or active ports and you will get this kind of output
If your port 161 and 162 for SNMP are not listed as active, then run command to open,then
and check updates on the firewall again with
Lastly check make sure you don't have special characters in your community tmli(make sure its correct)and correct ports and IPs for your target host.
Here is some good articles that will guide you on SNMP:
https://support.nagios.com/kb/article/s ... tocol.html
https://support.nagios.com/kb/article/snmp-tools.html
https://support.nagios.com/kb/article/n ... orial.html
Please let me know if you have any questions
systemctl start snmpd.service
systemctl status snmpd.service
snmpd.service - Simple Network Management Protocol (SNMP) Daemon.
Loaded: loaded (/usr/lib/systemd/system/snmpd.service; disabled; vendor preset: disabled)
Active: active (running) since Wed 2017-09-27 11:52:40 CDT; 32s ago
Main PID: 20304 (snmpd)
CGroup: /system.slice/snmpd.service
└─20304 /usr/sbin/snmpd -LS0-6d -f
OR
firewall-cmd --list-all
public (active)
target: default
icmp-block-inversion: no
interfaces: ens160
sources:
services: dhcpv6-client ssh
ports: 5666/tcp 161/tcp 80/tcp 5667/tcp 12489/tcp
protocols:
masquerade: no
forward-ports:
sourceports:
icmp-blocks:
rich rules:
firewall-cmd --zone=public --add-port=<161>/tcp --permanent
firewall-cmd --reload
