Disk Free Space - Specific Value
swiftarcher
Post by swiftarcher »
Sorry newbie here running Nagios 5.4.7.
Have rolled out the NSClient++ but need to have Disk Free Space - Specific Value implemented. Is there a way of doing this on a windows server.
Sorry I need to be spoon fed this because I have read the support site it says
NSClient++ via check_nrpe
NSClient++ includes a disk module. The thresholds for the disk checks are triggered if the free space is less than the supplied value.
Path: C:
Unit: GB
Warning: 10GB Free
Critical: 5GB Free
Command:
./check_nrpe -H 10.25.11.3 -c check_drivesize -a drive=C: 'warning=free<10G' 'critical=free<5G' show-all 'perf-config=*(unit:G)' detail-syntax='{${drive_or_name} ${free} free / ${size} total}' top-syntax='${status}: ${problem_list}'
Output:
OK: {C: 68.414GB free / 99.51GB total}|'C: free'=68.41361G;10;5;0;99.50976 'C: free %'=69%;10;5;0;100
But I cant get it to work sorry
npolovenko
Re: Disk Free Space - Specific Value
Post by npolovenko »
Hi, @swiftarcher. The command looks right. What output are you getting when you run the command?
swiftarcher
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
Also if I run check_nrpe on the client server I get
I <0.5.1.44 2017-08-30> seem to be doing fine...
Hope this helps
npolovenko
@swiftarcher, Can you upload the nsclient.log file from the remote windows server? It's in the same folder with nsclient.ini. Actually, please upload nsclient.ini as well. So two files.
swiftarcher
All uploaded thankyou
npolovenko
Hello, @swiftarcher.
Here're some options to change in nsclient.ini file:
; TODO
[/settings/NRPE/server]
allow arguments = true
allow nasty characters = true
port = 5666
; Undocumented key
verify mode = none
; Undocumented key
insecure = true
Also, your nsclient.log has lots of entries:
Rejected connection from: 10.10.10.1
I'd try to figure out where it comes from, and either add the IP to allowed hosts in nsclient.ini or do further investigation and stop that server from reaching out to NSClient.
swiftarcher
Thankyou just tried but still no joy
npolovenko
@ swiftarcher, What is your version of the NSCLient? As of right now we officially support 0.4.x, and these manuals were written for 0.4 as well.
DId you actually restart NSClient process after making the changes?
Please upload nsclient log file one more time.
swiftarcher
Client 0.4.4
Yep restated service after editing the .ini file
swiftarcher
npolovenko wrote:@ swiftarcher, What is your version of the NSCLient? As of right now we officially support 0.4.x, and these manuals were written for 0.4 as well.
I think the version is 0.5.1.44 I maybe mistaken.
Here are some screen shots on what I am doing
First off I ran nscp test on client machine ran check_drivesize command after loading the CheckDisk module.
Then restarted the service on the client machine and then proceeded to configure the Host on NagiosXI.
