Distributed Monitoring with Windows Environments
domsch1988
Re: Distributed Monitoring with Windows Environments
Post by domsch1988 »
kyang wrote:Yes, the GUI is pretty awesome.
Hmm, but that is interesting... When you added the passive check into the nrdp.cfg. Did you restart ncpa_passive service?
Can you PM or post your nrdp.cfg file for me?
Do you currently have NCPA installed on all of those Windows machines you are trying to get passive checks from?
Yes, i restart the service after every change. Otherwise the changes don't get applied.
And yes, NCPA on all Windows Hosts. Freshly installed 2.2.1.
My Configs from one Server i'm testing are attached (cleared from tokens and passwords ofc)
npolovenko
Post by npolovenko »
@domsch1988, Are you able to check the network interface with the following command from a Nagios server?
./check_ncpa.py -H 10.25.14.10 -t 'Str0ngT0k3n' -P 5693 -M 'interface/LAN-Verbindung-1/bytes_recv' -d -u k -w 10 -c 100
domsch1988
npolovenko wrote:@domsch1988, Are you able to check the network interface with the following command from a Nagios server?
Yes. And this works with or without spaces. With renaming the Interface i tested:
./check_ncpa.py -H 192.168.189.20 -t 'Token' -P 5693 -M 'interface/LAN-Verbindung 1/bytes_recv' -d -u k -w 10 -c 100
and
./check_ncpa.py -H 192.168.189.20 -t 'Token' -P 5693 -M 'interface/LAN-Verbindung-1/bytes_recv' -d -u k -w 10 -c 100
Both work as expected.
kyang
Post by kyang »
Since they are working just fine when running it from the CLI.
But it doesn't work for passive checks?
Are you receiving any errors in ncpa_passive.log? Which would be from the windows machine.
domsch1988
kyang wrote:Since they are working just fine when running it from the CLI.
The only thing i'm getting ars those indicating, that NCPA splits the commands and doesn't know what to do with the second part.
WARNING:ncpacheck:Unable to parse all arguments from instruction. Mis-paired option: 3/bytes_recv
kyang
Post by kyang »
Are you running this passive check? I don't see it inside your nrdp.cfg file?
Can you show me a screenshot of that from the NCPA gui while using the API? I would like to see how that node is being defined.
domsch1988
kyang wrote:Are you running this passive check? I don't see it inside your nrdp.cfg file?
Yes, this is running. Screenshots are attached. One "Normal" and one with "Run as Nagios Check"
kyang
Post by kyang »
Can you show me what the passive check looks like when you click "View in alternate format"
I know there are some special characters that don't work listed in the NCPA GitHub issues, so I wanted to make sure.
https://github.com/NagiosEnterprises/ncpa/issues/395
domsch1988
kyang wrote:Can you show me what the passive check looks like when you click "View in alternate format"
No Problem. The Actual Output copied:
%HOSTNAME%|<service name> = /interface/LAN-Verbindung-1/bytes_recv --warning 80 --critical 90 --units Gi
And a Screenshot to be sure:
Keep in mind, that i currently have the Adapter renamed to not have spaces so that the monitoring works. I was also able to reproduce the issue on at least 4 Windows Servers (stopped trying after that).
kyang
Post by kyang »
Interesting, I'll have to try and reproduce it that way our NCPA developer can fix it if possible.
I would like to mention there is a new NCPA release 2.1.3.
Were there any more questions on this or are we all set?
