Anyone using Nagios XI to monitor MongoDB queues?
I have searched and found various plug ins. However none of them have any ratings or reviews so does anyone out there use any of these plug ins to monitor their Mongo queues?
Re: Anyone using Nagios XI to monitor MongoDB queues?
There was a relatively lively thread in the customers section involving @jkinning:
https://support.nagios.com/forum/viewto ... 0&p=244204
The gist of it was that this plugin was used:
https://github.com/mzupan/nagios-plugin-mongodb
But it had some problems authenticating against newer mongodb versions.
- Support Tech
@robatwork, XI already comes with a MongoDB wizard. In the Web Interface go to Configure, then search for MongoDB.
What @mcapra said is correct, we are experiencing issues with new SCRAM-SHA authentication, and we are currently working on updating our plugin.
Thanks guys. After posting I did actually see those 2 options (server and database) and am trying them out.
Getting dozens of notifications about memory usage and negative numbers in the queues but will spend some time fettling the commands so nbo doubt I will be back with other threads!
Please close this one
