Error performance graphs in ten gigabit port switch.
dimsum
Post by dimsum »
My interface graph has a problem to display. see in the picture. what's wrong, so in another graph is works fine no problem to display. can you please help to fix that issue.
Thank you.
npolovenko
Re: Error performance graphs in ten gigabit port switch.
Post by npolovenko »
Hello, @dimsum. If you hover all the other parts of the graph do you see 0 MB as well? When bandwidth is too small it get's rounded to 0 automatically.
