Hi all.
I'm trying to deploy a new VM using your 'nagiosxi-5.4.12-64.ova' following the instruction in the page 'https://www.nagios.com/downloads/nagios ... sxi-ova-64'.
When I arrive at poitn to choose the host or cluster where to run the deployed template I obtain this error:
An internal error occurred in the vSphere Client.
Details: Index out of range. Required non-negative value and less than the size.
Parameter name: index
Or something like that. Of course I've the .zip generated with the error.
Maybe a problem with OVA file corrupted or a problem with my VMware vCenter Server?
Thanks for any help.
Alex.
Error during deploy OVF template
Re: Error during deploy OVF template
I would think it would likely be an issue with your esxi server as dozens of these ova files are successfully deployed every day. Which version of esxi and vsphere client are you running?
