I am trying to configure the process check in Nagios to get alert during database down.
Below is the check command working fine with the result"OK: Process count for processes named ora_pmon_databasename was 1"
-t 'xxxxxxxx' -P xxxx -M 'processes' -c 1: -q 'name=ora_pmon_xxxx,match=search'
I am not sure when we get an alert during database down.
If database down, threshold comes to 0 and will get an alert?
Can anyone please explain and clarify the doubts?
Appreciated everyone help here.
Anand
Process Check Alert in Nagios
Re: Process Check Alert in Nagios
That would depend on what plugin you're using. The plugin name is not included in your original post, so all we can do is assume the plugin being used based on the arguments you've provided.akumarhe1868 wrote: If database down, threshold comes to 0 and will get an alert?
I'll assume this is an NCPA based check using check_ncpa.py. Here is the documentation for the processes module:
https://www.nagios.org/ncpa/help.php#ap ... -processes
Which, based on the query of name=ora_pmon_xxxx,match=search, will return a problem status (> 0) if the binary name of ora_pmon_xxxx does not appear in a search of all processes. The process could be totally hung, the ports could no longer be listening, but as long as it is indeed registered as a Linux process the check will return an OK status (0).
- Support Tech
No Questions. Thanks.
