Hi
We're running Nagios XI version 5.5.1.
We recently resolved an issue with performance graphs not populating. As part of this fix i thought capacity planning may have started to work but it hasn't
When i go to Reports > Capacity Planning, the hosts/services which have perf data are not showing any data on the capacity planning graph - they're all blank.
I'm not sure what logs to check etc, any help much appreciated.
Sarah
Capacity planning graphs are blank
Re: Capacity planning graphs are blank
How long has the perf graph issue been fixed and what time period is the report running for? Issues with performance graphing can impact capacity planning until enough valid data is collected again. Per https://assets.nagios.com/downloads/nag ... anning.pdf:
You must have twice as much solid data as the period you wish to use. A caveat of this is that if the data that
you are gathering is spotty, capacity planning will not work. Capacity planning also requires that 66% of the
period you wish to extrapolate with must have real values. If Nagios goes down, or the plugin that you're
using starts malfunctioning and performance data does not get recorded, that starts adding to the 66% of
values that are not acceptable values for number crunching.
Ok great i thnik that explains it - it's on the default setting of 1 week period.
The issue was fixed this time last week so we'll need another week for this to start appearing.
Thanks again
Sarah
Thanks again
Sarah
Let us know if they don't start once the amount of time has passed.opsadmin wrote:Ok great i thnik that explains it - it's on the default setting of 1 week period.
Thanks again
Sarah
Hi Scott
Unfortunately the capacity planning graphs are still blank.
Would you like me to PM you our Nagios system profile?
Sarah
Sarah
You can PM the profile to any member of the Nagios Support team. Thanks!
Perfect thanks, I've received your reply to my PM. Look forward to seeing what the issue could be and resolving it
ImportError: No module named numpy
Traceback (most recent call last):
File "/usr/local/nagiosxi/html/includes/components/capacityplanning/backend/capacityplanning.py", line 7, in <module>
import rrddatastore
File "/usr/local/nagiosxi/html/includes/components/capacityplanning/backend/rrddatastore.py", line 3, in <module>
import numpy as np
yum install numpy
If it's not, please run this tail command (and leave it running):
tail -F /var/log/httpd/error_log /var/log/httpd/ssl_error_log
Thank you
