Hello Team,
I tried to remove from the command line all autodiscoveries that were more than 365 days old but for some reason i must have missed something cause they still show in the GUI and are all just spinning. The ones older than a year do not list a date and they are spinning and the ones a year or newer are spinning too.
I did a find -mtime +365 -delete in cd /usr/local/nagiosxi/html/includes/components/autodiscovery/jobs
One thing that looked odd to me is the screenshot that i will attach. Fore some reason there are a bunch of entries that didnt get deleted cause the date stamp looks like a time stamp. Please advise on this as well.
Please let me know what i missed.
Thank you,
Matt
How do i remove Autodiscovery Jobs Completely from CMD
Re: How do i remove Autodiscovery Jobs Completely from CMD
I added a Discovery Job and all jobs that are less than 1 year have now stopped spinning.
The ones on top are older than a year the ones on the bottom are less than a year. I need to completely remove all more than 365 days old and had to resort to the command line to accomplish this as there are no bulk removals for Autodiscovery Jobs and hitting the red X hundreds of times while waiting for the page to refresh between each was a dreadful option.
Sorry, uploaded the screenshot that i should have attached to the first reply. This is the one that i meant to post last
Yo! How goes it brother?
I looked into this and you'll likely need to click the red X next to them unfortunately, the reason why is that the autodiscovery jobs are stored in the DB, the result files are stored on the filesystem but the jobs would still be listed regardless.
Or if you're using postgresql:
It's actually stored as a php serialized object:
You can take a look at what it un-serializes to uses this:
https://www.unserialize.com
echo "select * from xi_options where name = 'autodiscovery_jobs';" | mysql -uroot -pnagiosxi nagiosxi
echo "select * from xi_options where name = 'autodiscovery_jobs';" | psql nagiosxi nagiosxi
[root@xid nagios]# echo "select * from xi_options where name = 'autodiscovery_jobs';" | mysql -uroot -pnagiosxi nagiosxi
option_id name value
31 autodiscovery_jobs a:3:{s:6:"b5H2FE";a:10:{s:7:"address";s:17:"192.168.232.10/16";s:15:"exclude_address";s:0:"";s:12:"os_detection";s:2:"on";s:18:"topology_detection";s:2:"on";s:10:"system_dns";s:2:"on";s:9:"initiator";s:11:"nagiosadmin";s:10:"start_date";i:1539374940;s:9:"scandelay";s:0:"";s:9:"frequency";s:5:"Daily";s:8:"schedule";a:5:{s:4:"hour";s:2:"09";s:6:"minute";s:2:"00";s:4:"ampm";s:2:"AM";s:9:"dayofweek";s:1:"1";s:10:"dayofmonth";s:1:"1";}}s:6:"DGHg2a";a:10:{s:7:"address";s:17:"192.168.232.20/16";s:15:"exclude_address";s:0:"";s:12:"os_detection";s:2:"on";s:18:"topology_detection";s:2:"on";s:10:"system_dns";s:2:"on";s:9:"initiator";s:11:"nagiosadmin";s:10:"start_date";i:1539374977;s:9:"scandelay";s:0:"";s:9:"frequency";s:4:"Once";s:8:"schedule";a:5:{s:4:"hour";s:2:"09";s:6:"minute";s:2:"00";s:4:"ampm";s:2:"AM";s:9:"dayofweek";s:1:"1";s:10:"dayofmonth";s:1:"1";}}s:6:"sOpXf2";a:10:{s:7:"address";s:17:"192.168.232.21/16";s:15:"exclude_address";s:0:"";s:12:"os_detection";s:2:"on";s:18:"topology_detection";s:2:"on";s:10:"system_dns";s:2:"on";s:9:"initiator";s:11:"nagiosadmin";s:10:"start_date";i:1539375005;s:9:"scandelay";s:0:"";s:9:"frequency";s:5:"Daily";s:8:"schedule";a:5:{s:4:"hour";s:2:"09";s:6:"minute";s:2:"02";s:4:"ampm";s:2:"AM";s:9:"dayofweek";s:1:"1";s:10:"dayofmonth";s:1:"1";}}}
Mr. Sax, so we meet again.
I was really hoping you were going to have an out for me on this. Not much more that i can say that i have not said already on this. Maybe one day when everything in Nagios is Green and i got nothing to do for hours on end ill start hitting the red X. . Thanks for the reply and try to have a good weekend.
Talk soon,
Matt
Talk soon,
Matt
What about if we deleted them all and then had you just recreate the ones you want, would that work for you or do you have a ton of them that you'd have to recreate?
