i have Nagios Xi 5.5.5 version installed on RHEL 7.3, when i tried to monitor Nagios Xi engine as different host i am getting the following error.
(No output on stdout) stderr: connect to address port 5666: Connection refused
i have a previous post on this but i didn't find /etc/xinetd.d/nrpe but i found /etc/xinetd.d/nsca
https://support.nagios.com/forum/viewto ... =6&t=48797
vi /etc/xinetd.d/nsca
# default: on
# description: NSCA (Nagios Service Check Acceptor)
service nsca
flags = REUSE
socket_type = stream
wait = no
user = nagios
group = nagios
server = /usr/local/nagios/bin/nsca
server_args = -c /usr/local/nagios/etc/nsca.cfg --inetd
log_on_failure += USERID
disable = no
only_from = 127.0.0.1 IP address
restarted Xinetd service but still am getting the same error.
- Support Tech
Re: connect to address port 5666: Connection refused
Hello, @Johnsmit. NSCA is a different agent from the NRPE. It is quite unusual that you don't have the nrpe config in the xinetd folder.
Can you show me the output of these commands?
ll /usr/local/nagios/bin
ll /etc/xinetd.d/
rwxr-xr-x 1 root root 222128 May 2 11:12 nrpenpolovenko wrote:Hello, @Johnsmit. NSCA is a different agent from the NRPE. It is quite unusual that you don't have the nrpe config in the xinetd folder.
Can you show me the output of these commands?ll /usr/local/nagios/bin
ll /etc/xinetd.d/
-rwxr-xr-x 1 root root 10683 May 2 11:12 nrpe-uninstall
total 44
-rw------- 1 root root 1157 Mar 3 2016 chargen-dgram
-rw------- 1 root root 1159 Mar 3 2016 chargen-stream
-rw------- 1 root root 1157 Mar 3 2016 daytime-dgram
-rw------- 1 root root 1159 Mar 3 2016 daytime-stream
-rw------- 1 root root 1157 Mar 3 2016 discard-dgram
-rw------- 1 root root 1159 Mar 3 2016 discard-stream
-rw------- 1 root root 1148 Mar 3 2016 echo-dgram
-rw------- 1 root root 1150 Mar 3 2016 echo-stream
-rw------- 1 root root 1212 Mar 3 2016 tcpmux-server
-rw------- 1 root root 1149 Mar 3 2016 time-dgram
-rw------- 1 root root 1150 Mar 3 2016 time-stream
- Support Tech
@Johnsmit, Looks like you still have the nrpe binary. Let's try recreating the config in the /etc/xinetd.d/.
Create the nrpe file and put the following content inside.
Give it the following permissions:# default: on
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
flags = REUSE
port = 5666
wait = no
user = nagios
group = nagios
server = /usr/local/nagios/bin/nrpe
server_args = -c /usr/local/nagios/etc/nrpe.cfg --inetd
disable = yes
Restart xinetd:chmod 644 nrpe
Then run the following command:service xinetd restart
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
