I'm using Nagios XI at my environment and want to integrate with a third party ticketing system, but i m unable to find any documentation on Internet. I want to integrate it with Manage Engine or Service Desk which ever is best. My requirement is that whenever an alert is generated on nagios, A ticket should be automatically created on the ticketing system and when the alert gets cleared the opened ticket should automatically get closed.
I tried to search it on nagios exchange forum but only found plugins and not any documentation as how to integrate it.
Integrate Nagios with Third Party Ticketing tool
- Support Tech
Re: Integrate Nagios with Third Party Ticketing tool
Hello, @sona9768. I'm not familiar with the mentioned ticketing systems, but generally speaking, the goal is to find a script or a command that nagios can execute to open and close tickets on the ticketing system. This could be an API command or a script. Then you'd set up nagios to trigger that script every time a host or a service check produces an alert.
Here's an article on using event handlers with Nagios:
In your case, the event handler would be a script that opens or closes tickets in the ticketing system.
A convenient hook for opening/closing tickets in the ticketing system might be the REST API for the respective platforms:npolovenko wrote:In your case, the event handler would be a script that opens or closes tickets in the ticketing system.
https://www.manageengine.com/api/
https://help.servicedeskplus.com/api/rest-api.html
curl is a cli-based web client that ships with practically all CentOS and RHEL installations. In this example, I create a Nagios event handler that integrates a Nagios Core installation with the Twilio API:
https://support.nagios.com/forum/viewto ... 94#p252294
Though this would look a bit different in Nagios XI, the principle remains the same. You configure an event handler command, then feed information about a specific alert (via macros) into that command. I imagine you could rig up a curl call to communicate with Manage Engine or Service Desk just as well.
Hopefully the advice from @mcapraand @npolovenko are enough to get you in the right direction, @sona9768. Let us know if you have any additional questions we can help with.
