CRITICAL - Plugin timed out while executing system call
Soumya2925
Post by Soumya2925 »
Hi Team,
Suddenly iam getting lot of alerts for check_snmp:
"CRITICAL - Plugin timed out while executing system call"
configured command is: check_snmp:
$USER1$/check_snmp -H $HOSTADDRESS$ $ARG1$
Can you please advice on this
npolovenko
Re: CRITICAL - Plugin timed out while executing system call
Post by npolovenko »
Hello, @Soumya2925. Perhaps the SNMP community string changed? Can you test this by running an snmp walk command against the server?
Also, please execute the command you sent me from the command line with all arguments and share the output.
Soumya2925
Hi Npolovenko,
Attached the files.
ssax
Dreams In Code
Post by ssax »
Looks like you're missing some MIBs.
Please run this command and PM one of us the resulting /tmp/SNMPFILES.zip file:
zip -r /tmp/SNMPFILES.zip /etc/snmp /usr/share/snmp/mibs
Thank you!
Soumya2925
Attached the zip file.
ssax
Dreams In Code
Post by ssax »
Looks like you're missing CISCO-SMI, please upload that MIB and then send me the full output of this command so that I can view the permissions:
ls -l /usr/share/snmp/mibs
