Hi Team,
I have install the nrpe agent and configure one Linux node in Nagios XI. When we check the status of service the some of monitor show like " nrpe : command 'check_disk' not defined.
I tried many way, but stil the same thing. Could you please help me to fix this.
I check the nrpe config file and update accordingly. Took the nrpe restart.
But the same time some of monitor is working like CPU load,
Regards
Shtrudhan
nrpe: command 'check_disk' not defined
Re: nrpe: command 'check_disk' not defined
Can you share the nrpe.cfg from the remote server?
Hi
Please find the attachment. i need to report to nagios XI server. Please help me to fix this.
The check_disk line is commented out, you need to replace this:
With this
then restart nrpe
#command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
