Step-1
We are trying to integrate Nagios XI with symphony ticketing tool but there is no any API available for the same.
Step-2
Please suggest the API use for the integration of Nagios XI with symphony with the same alert phassion. Symphony is already given API for our end. API from the Nagios XI side to resend alert to symphony.
Step-3
Please provide contact number for the communication.
Need help for Nagios Integration with symphony
Re: Need help for Nagios Integration with symphony
I'm not finding any information or plugins for Symphony, but if it has an API you can use event handlers in XI to run scripts that create tickets in the system: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
Feel free to call(https://www.nagios.com/contact/)or open a ticket at https://support.nagios.com/tickets/ if you have a support license.
Thanks for reply team. I have gone through the document and i have tried at command level it is working fine, but i have couple of questions can you please respond.
1. The shell script which is going to execute after getting the alert can it be replace with my own shell script in which i would like to call API of the external system and pass the parameters.
2. Where is the path location of this script.
Yes.1. The shell script which is going to execute after getting the alert can it be replace with my own shell script in which i would like to call API of the external system and pass the parameters.
Most scripts are stored in /usr/local/nagios/libexec/. The location of the example used in the document is /usr/local/nagios/libexec/event_handler_test.sh.2. Where is the path location of this script.
I have deleted your other forum post, please do not create duplicate posts for the same issue, please continue using this forum thread for any questions related to this.
You can either use event handlers as cdienger suggested or use Admin > Manage Components > SNMP Trap Sender component to send traps but you'll likely need to write your own even handler to handle this stuff if Symphony doesn't give you anything other than an API.
Here are the current ones that I've found, you'll likley need to use one of them as a reference in developing your own component or event handler to work with Symphony:
https://exchange.nagios.org/directory/A ... Ticketing/
Please read this document all the way through to get a really good idea of how you're going to need to do this:
https://assets.nagios.com/downloads/nag ... dlers.html
See here too:
If you have any questions or need clarification on anything, let us know.
Thank you!
See here too:
Thank you!
Hello team,
I have configured SMTP in Nagios XI and tested by sending the test email. But when trying to send email through shell script the email is not triggering. I am attaching the script, kindly look into this.
When you run the command from the command line (while in SSH), what does it output?
Please PM me a fresh copy of your profile, you can download it from Admin > System Profile > Download Profile.
Additionally, please attach that script in code blocks or as an attachment, I'm not going to type it out by hand.
Are you setting it as an event handler on a service? If so, which host/service so that I can see how you have it setup.
Are you defining it as the notification command for a specific contact? If so, which contact?
Thank you!
Thank you!
The output screen shot "event-handler-output" is attached. The shell script prints only echo and does not go into the if statement.
I have copied the shell script in a txt file "event-handler-test.sh.txt"
Also attaching the fresh profile.
I am setting it as an event handler on a service. The host/service information is attached as a screenshot "event-handler-host".
I am attaching the profile.zip separately as it allowed attaching only 3 files.
So the command is defined like this
In order to get into the if statement $4 needs to be test, but in your screenshot show that $HOSTOUTPUT$ is OK
command_name event_handler_test
command_line $USER1$/event_handler_test.sh $HOSTNAME$ $HOSTSTATE$ $HOSTSTATETYPE$ $HOSTOUTPUT$
