NRPE connection intermittent, services fail to capture data
s.wiki
Post by s.wiki »
Hi
Currently i facing one server that having intermittently connection from NRPE, when i try to ping from monitored host to Nagios Xi, connection work find.
benjaminsmith
Re: NRPE connection intermittent, services fail to capture d
Post by benjaminsmith »
Hi @s.wiki,
If this is an intermittent issue and you can ping the host, I would try increasing the timeout settings on check command. Is it happening to all the service checks on the host?
Take a look at this knowledgebase article for instructions to increase the timeout settings:
NRPE - CHECK_NRPE: Socket Timeout After n Seconds
Let us know if you get it worked out.
