- About JMX (check_jmx4perl):
I attache evidences of the Java: But shows now this error:
[root@nagiosxi-rh libexec]# /usr/local/nagios/libexec/check_jmx --timeout=10 --url=http://10.16.70.129:8080/jolokia --config=/usr/local/nagios/etc/jmx4perl/memory.cfg --check=memory_heap 90 80
JMX UNKNOWN Required options not specified Usage: check_jmx -help
- About VMWARE
Ok:
I attache evidences of the Perl Module for the new plugin: The check_esx3.pl file is overwritten by this new:cp /usr/local/nagios/libexec/check_esx3.pl /usr/local/nagios/libexec/check_esx3.pl.old
But shows the same error:Then download this updated plugin to your PC.
https://github.com/shinken-monitoring/p ... ck_esx3.pl
[root@nagiosxi-rh libexec]# ./check_esx3.pl -H esxbigdata.trabajo.dom -f /usr/local/nagiosxi/etc/components/vmware/monitorizacion.txt -l RUNTIME
length() used on @array (did you mean "scalar(@array)"?) at /usr/lib64/perl5/IO/Compress/Zlib/Extra.pm line 198, <AUTH_FILE> line 2.
CHECK_ESX3.PL OK - 12/12 VMs up, overall status=green, connection state=connected, maintenance=no, All 219 health checks are Green, no config issues | vmcount=12units;; health_issues=0;; config_issues=0;;
CHECK_ESX3.PL CRITICAL - SOAP request error - possibly a protocol issue: 500 read timeout
Thank you very much for the attention received
