Performance Graphs suddenly stopped populating
We are in about day 24 of our Nagios XI evaluation, and unfortunately it stopped populating the graphs out of nowhere yesterday.
Running 5.6.3 via VMWare OVA on CentOS 7.6.1810 (part of the XI provided ova file). System Profile is attached.
I've searched through the forums and tried about everything that has been posted to no avail.
We went from a beautiful real time dashboard depicting our Core Network utilization and auto generated reports: To this ... I get the same results for any performance graphs across our 5 hosts and 5,000+ services.
Any ideas? I am on a time crunch, and was supposed to do a presentation on Monday showing off Nagios XI capabilities. I am worried I may need to start over from scratch.
Would changing the root password on the server cause this? As I started hardening the box to open up the email capabilities, I changed the root password, and disabled SSH from external sources. Those were the only two changes made. I also installed netstat via yum so that i could confirm no bad guys were connecting on open ports. All pretty standard stuff, so I wouldnt expect any of those to cause issues internal to Nagios.
Thanks in advance for the help! This is one of the best forums I've ever experienced.
Aloha,
Joe
Aloha,
Joe
Re: Performance Graphs suddenly stopped populating
Is it just the Bandwidth graphs failing to populate?
If so, can you run the following commands as root and post the the /tmp/mrtg.txt file here?
If it is all of the graphs, restart the following daemon to see if that fixes the issue.
Let the system run for 20 to 30 minutes and if the graphs still do not work, post the following files so we can view them.
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg -debug=cfg,base,log &> /tmp/mrtg.txt
LANG=C LC_ALL=C /usr/bin/mrtg &>> /tmp/mrtg.txt
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok --user=nagios --group=nagios &>> /tmp/mrtg.txt
{ time LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg 2>1 ; } 2>> /tmp/mrtg.txt
service npcd restart
/usr/local/nagios/var/perfdata.log
/usr/local/nagios/var/npcd.log
Hi There,
Yes, it appears that only the Performance Graphs are failing to populate. The Host RTT graphs appear to be fine, though that doesnt really provide what we are after for per interface stats.
I tried restarting npcd last week as part of my initial troubleshooting and no errors were apparent upon restart.
I went ahead and restarted it again, waited 30 minutes and still no performance graph data. Here are the results of the mrtg.txt, perfdata and npcd log files as requested. The mrtg.txt output was 34MB so I had to break it up into two separate files.
Sincererly appreciate the insight and feedback!
Joe
Joe
I did not find any errors in the MRTG files so let's try and run the plugin command on the server as the nagios user and verbose to see if there are any errors.
Login to a shell to the server and run this to switch to the nagios user
Run this to see what the verbose output of the plugin shows. Put in a valid IP address for Y.Y.Y.21
Post the output as well as the output from this command ran as root.
su - nagios
/usr/local/nagios/libexec/check_rrdtraf -f /var/lib/mrtg/Y.Y.Y.21_436379648.rrd -w 5.00,5.00 -c 8.00,8.00 -l G -v
ps -ef --cols=300
Here is the output. I checked another .rrd file for the trunk interface which I know should be reporting a massive amount of traffic, though it is showing 0 as well.
and ...
OK - Current BW in: 0Gbps Out: 0Gbps|in=0Gb/s;5.00;8.00 out=0Gb/s;5.00;8.00
[nagios@localhost ~]$ ps -ef --cols=300
UID PID PPID C STIME TTY TIME CMD
root 1 0 0 Jun27 ? 00:08:36 /usr/lib/systemd/systemd --switched-root --system --deserialize 22
root 2 0 0 Jun27 ? 00:00:00 [kthreadd]
root 3 2 0 Jun27 ? 00:00:04 [ksoftirqd/0]
root 5 2 0 Jun27 ? 00:00:00 [kworker/0:0H]
root 7 2 0 Jun27 ? 00:01:25 [migration/0]
root 8 2 0 Jun27 ? 00:00:00 [rcu_bh]
root 9 2 0 Jun27 ? 00:08:19 [rcu_sched]
root 10 2 0 Jun27 ? 00:00:00 [lru-add-drain]
root 11 2 0 Jun27 ? 00:00:02 [watchdog/0]
root 12 2 0 Jun27 ? 00:00:02 [watchdog/1]
root 13 2 0 Jun27 ? 00:01:21 [migration/1]
root 14 2 0 Jun27 ? 00:00:02 [ksoftirqd/1]
root 16 2 0 Jun27 ? 00:00:00 [kworker/1:0H]
root 17 2 0 Jun27 ? 00:00:02 [watchdog/2]
root 18 2 0 Jun27 ? 00:01:24 [migration/2]
root 19 2 0 Jun27 ? 00:00:03 [ksoftirqd/2]
root 21 2 0 Jun27 ? 00:00:00 [kworker/2:0H]
root 22 2 0 Jun27 ? 00:00:02 [watchdog/3]
root 23 2 0 Jun27 ? 00:01:23 [migration/3]
root 24 2 0 Jun27 ? 00:00:06 [ksoftirqd/3]
root 26 2 0 Jun27 ? 00:00:00 [kworker/3:0H]
root 28 2 0 Jun27 ? 00:00:00 [kdevtmpfs]
root 29 2 0 Jun27 ? 00:00:00 [netns]
root 30 2 0 Jun27 ? 00:00:00 [khungtaskd]
root 31 2 0 Jun27 ? 00:00:00 [writeback]
root 32 2 0 Jun27 ? 00:00:00 [kintegrityd]
root 33 2 0 Jun27 ? 00:00:00 [bioset]
root 34 2 0 Jun27 ? 00:00:00 [bioset]
root 35 2 0 Jun27 ? 00:00:00 [bioset]
root 36 2 0 Jun27 ? 00:00:00 [kblockd]
root 37 2 0 Jun27 ? 00:00:00 [md]
root 38 2 0 Jun27 ? 00:00:00 [edac-poller]
root 39 2 0 Jun27 ? 00:00:00 [watchdogd]
root 45 2 0 Jun27 ? 00:00:00 [kswapd0]
root 46 2 0 Jun27 ? 00:00:00 [ksmd]
root 47 2 0 Jun27 ? 00:01:24 [khugepaged]
root 48 2 0 Jun27 ? 00:00:00 [crypto]
root 56 2 0 Jun27 ? 00:00:00 [kthrotld]
root 58 2 0 Jun27 ? 00:00:00 [kmpath_rdacd]
root 59 2 0 Jun27 ? 00:00:00 [kaluad]
root 62 2 0 Jun27 ? 00:00:00 [kpsmoused]
root 64 2 0 Jun27 ? 00:00:00 [ipv6_addrconf]
root 77 2 0 Jun27 ? 00:00:00 [deferwq]
root 112 2 0 Jun27 ? 00:00:06 [kauditd]
apache 519 8031 0 Jul01 ? 00:00:47 /usr/sbin/httpd -DFOREGROUND
root 1625 2 0 14:33 ? 00:00:00 [kworker/0:2]
root 1941 8017 0 Jul01 ? 00:00:00 sshd: root@pts/1
root 1982 1941 0 Jul01 pts/1 00:00:00 -bash
root 2348 7416 0 15:28 ? 00:00:00 /usr/sbin/CROND -n
root 2349 7416 0 15:28 ? 00:00:00 /usr/sbin/CROND -n
root 2351 7416 0 15:28 ? 00:00:00 /usr/sbin/CROND -n
root 2352 7416 0 15:28 ? 00:00:00 /usr/sbin/CROND -n
root 2353 7416 0 15:28 ? 00:00:00 /usr/sbin/CROND -n
nagios 2359 2348 0 15:28 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1
nagios 2365 2349 0 15:28 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1
nagios 2367 2353 0 15:28 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1
nagios 2368 2351 0 15:28 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1
nagios 2369 2365 0 15:28 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php
nagios 2370 2352 0 15:28 ? 00:00:00 /bin/sh -c /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1
nagios 2371 2359 0 15:28 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php
nagios 2372 2367 0 15:28 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php
nagios 2373 2370 0 15:28 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php
nagios 2375 2368 0 15:28 ? 00:00:00 /usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php
root 2393 2 0 15:28 ? 00:00:00 [kworker/3:0]
root 2527 2 0 Jun27 ? 00:00:00 [mpt_poll_0]
root 2544 2 0 Jun27 ? 00:00:00 [mpt/0]
root 2581 2 0 Jun27 ? 00:00:00 [ata_sff]
root 2638 2 0 Jun27 ? 00:00:00 [scsi_eh_0]
root 2678 2 0 Jun27 ? 00:00:00 [scsi_tmf_0]
root 2743 2 0 Jun27 ? 00:00:00 [scsi_eh_1]
root 2745 2 0 Jun27 ? 00:00:00 [scsi_tmf_1]
root 2753 2 0 Jun27 ? 00:00:00 [scsi_eh_2]
root 2757 2 0 Jun27 ? 00:00:00 [scsi_tmf_2]
root 2762 2 0 Jun27 ? 00:00:00 [ttm_swap]
root 2768 2 0 Jun27 ? 00:00:00 [irq/16-vmwgfx]
root 3186 11550 0 Jul01 ? 00:00:00 /usr/libexec/openssh/sftp-server
apache 3347 8031 0 Jul01 ? 00:00:53 /usr/sbin/httpd -DFOREGROUND
root 3655 2 0 Jun27 ? 00:00:00 [kworker/0:1H]
root 3695 2 0 Jun27 ? 00:00:00 [kdmflush]
root 3697 2 0 Jun27 ? 00:00:00 [bioset]
root 3709 2 0 Jun27 ? 00:00:00 [kdmflush]
root 3711 2 0 Jun27 ? 00:00:00 [bioset]
root 3717 2 0 14:54 ? 00:00:00 [kworker/1:2]
root 3756 2 0 Jun27 ? 00:00:50 [jbd2/dm-0-8]
root 3757 2 0 Jun27 ? 00:00:00 [ext4-rsv-conver]
root 3828 1 0 Jun27 ? 00:03:02 /usr/lib/systemd/systemd-journald
root 3854 1 0 Jun27 ? 00:00:00 /usr/sbin/lvmetad -f
root 3861 1 0 Jun27 ? 00:00:00 /usr/lib/systemd/systemd-udevd
root 5205 2 0 15:08 ? 00:00:00 [kworker/3:1]
apache 5501 8031 0 Jun30 ? 00:02:15 /usr/sbin/httpd -DFOREGROUND
nagios 5666 1 0 Jun28 ? 00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg -f
root 6494 2 0 14:34 ? 00:00:00 [kworker/u64:1]
root 6591 2 0 15:22 ? 00:00:00 [kworker/3:3]
nagios 7039 22750 0 15:28 pts/0 00:00:00 ps -ef --cols=300
root 7074 2 0 Jun27 ? 00:00:00 [jbd2/sda1-8]
root 7086 2 0 Jun27 ? 00:00:00 [ext4-rsv-conver]
root 7381 1 0 Jun27 ? 00:00:32 /sbin/auditd
root 7405 1 0 Jun27 ? 00:00:49 /usr/sbin/irqbalance --foreground
dbus 7408 1 0 Jun27 ? 00:07:04 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
polkitd 7414 1 0 Jun27 ? 00:02:10 /usr/lib/polkit-1/polkitd --no-debug
root 7415 1 0 Jun27 ? 00:03:01 /usr/lib/systemd/systemd-logind
root 7416 1 0 Jun27 ? 00:00:19 /usr/sbin/crond -n
chrony 7440 1 0 Jun27 ? 00:01:38 /usr/sbin/chronyd
root 7455 1 0 Jun27 ? 00:01:13 /usr/bin/python -Es /usr/sbin/firewalld --nofork --nopid
root 7456 2 0 Jun27 ? 00:00:00 [kworker/1:1H]
root 7457 2 0 Jun27 ? 00:00:01 [kworker/3:1H]
root 7458 1 0 Jun27 ? 00:01:08 /usr/sbin/NetworkManager --no-daemon
root 8016 1 0 Jun27 ? 00:00:10 /usr/sbin/snmptrapd -Ln -f
root 8017 1 0 Jun27 ? 00:00:01 /usr/sbin/sshd -D
root 8018 1 0 Jun27 ? 00:00:58 /usr/bin/python2 -Es /usr/sbin/tuned -l -P
root 8024 1 0 Jun27 ? 00:01:27 /usr/sbin/rsyslogd -n
root 8031 1 0 Jun27 ? 00:00:23 /usr/sbin/httpd -DFOREGROUND
shellin+ 8032 1 0 Jun27 ? 00:00:00 /usr/sbin/shellinaboxd -u shellinabox -g shellinabox --cert=/var/lib/shellinabox --port=7878 --disable-ssl-menu -s /:SSH --localhost-only --css white-on-black.css
root 8038 1 0 Jun27 ? 00:00:00 /usr/sbin/xinetd -stayalive -pidfile /var/run/xinetd.pid
shellin+ 8043 8032 0 Jun27 ? 00:00:00 /usr/sbin/shellinaboxd -u shellinabox -g shellinabox --cert=/var/lib/shellinabox --port=7878 --disable-ssl-menu -s /:SSH --localhost-only --css white-on-black.css
mysql 8141 1 0 Jun27 ? 00:00:00 /bin/sh /usr/bin/mysqld_safe --basedir=/usr
mysql 8476 8141 1 Jun27 ? 01:20:27 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --plugin-dir=/usr/lib64/mysql/plugin --log-error=/var/log/mariadb/mariadb.log --pid-file=/var/run/mariadb/mariadb.pid --socket=/var/lib/mysql/mysql.sock
root 8523 1 0 Jun27 ? 00:00:06 /usr/libexec/postfix/master -w
postfix 8525 8523 0 Jun27 ? 00:00:05 qmgr -l -t unix -u
root 8566 1 0 Jun27 ? 00:00:07 /usr/bin/perl /usr/sbin/snmptt --daemon
snmptt 8567 8566 0 Jun27 ? 00:00:13 /usr/bin/perl /usr/sbin/snmptt --daemon
root 8708 2 0 Jun27 ? 00:00:00 [kworker/2:1H]
root 8728 1 0 Jun27 ? 00:00:00 login -- root
root 11318 2 0 15:23 ? 00:00:00 [kworker/2:1]
root 11550 8017 0 Jun28 ? 00:00:00 sshd: root@pts/0
root 11583 11550 0 Jun28 pts/0 00:00:00 -bash
apache 12540 8031 0 Jun28 ? 00:04:42 /usr/sbin/httpd -DFOREGROUND
postfix 13426 8523 0 13:54 ? 00:00:00 pickup -l -t unix -u
root 14748 2 0 15:10 ? 00:00:00 [kworker/2:0]
nagios 16728 1 0 Jul01 ? 00:00:06 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
apache 21279 8031 0 Jul01 ? 00:00:56 /usr/sbin/httpd -DFOREGROUND
apache 21908 8031 0 Jul01 ? 00:01:00 /usr/sbin/httpd -DFOREGROUND
root 22749 11583 0 15:25 pts/0 00:00:00 su - nagios
nagios 22750 22749 0 15:25 pts/0 00:00:00 -bash
apache 24292 8031 0 Jun27 ? 00:04:49 /usr/sbin/httpd -DFOREGROUND
nagios 25033 1 0 Jun27 ? 00:00:52 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
root 26608 2 0 15:26 ? 00:00:00 [kworker/u64:0]
nagios 26907 1 0 Jun30 ? 00:10:37 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 26908 26907 0 Jun30 ? 00:00:42 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 26909 26907 0 Jun30 ? 00:00:42 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 26910 26907 0 Jun30 ? 00:00:43 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 26911 26907 0 Jun30 ? 00:00:42 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 26912 26907 0 Jun30 ? 00:00:43 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 26913 26907 0 Jun30 ? 00:00:42 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 26915 5666 0 Jun30 ? 00:01:04 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg -f
nagios 26916 26915 0 Jun30 ? 00:12:49 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg -f
nagios 26940 26907 0 Jun30 ? 00:00:16 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
apache 27347 8031 0 15:26 ? 00:00:00 /usr/sbin/httpd -DFOREGROUND
root 29383 2 0 15:20 ? 00:00:00 [kworker/1:1]
root 29430 8728 0 Jun27 tty1 00:00:00 -bash
root 31161 2 0 14:46 ? 00:00:00 [kworker/0:1]
root 31456 2 0 15:20 ? 00:00:00 [kworker/u64:2]
apache 31940 8031 0 Jun27 ? 00:04:38 /usr/sbin/httpd -DFOREGROUND
apache 31984 8031 0 Jul01 ? 00:00:44 /usr/sbin/httpd -DFOREGROUND
root 32183 2 0 15:00 ? 00:00:00 [kworker/0:0]
[root@localhost mrtg]# su - nagios
[nagios@localhost ~]$ /usr/local/nagios/libexec/check_rrdtraf -f /var/lib/mrtg/Y.Y.Y.21_436379648.rrd -w 5.00,5.00 -c 8.00,8.00 -l G -v
Using RRD file: /var/lib/mrtg/Y.Y.Y.21_436379648.rrd
Fetching data with command: rrdtool fetch /var/lib/mrtg/Y.Y.Y.21_436379648.rrd AVERAGE -s-10minutes | grep -vi "nan"
[nagios@localhost ~]$ /usr/local/nagios/libexec/check_rrdtraf -f /var/lib/mrtg/X.X.X.212_9000212.rrd -w 5.00,5.00 -c 8.00,8.00 -l G -v
Using RRD file: /var/lib/mrtg/X.X.X.212_9000212.rrd
Fetching data with command: rrdtool fetch /var/lib/mrtg/X.X.X.212_9000212.rrd AVERAGE -s-10minutes | grep -vi "nan"
What is the speed of the trunk interface?
Can you post one of the rrd files from the /var/lib/mrtg folder so we can dump it and view the contents?
One more thing, check the cron log
to see if there are any errors when it runs the MRTG application to gather the data from the devices.
/var/log/cron
When I checked the /var/log/cron file, NOW we are getting somewhere ... It looks like we are getting the following error, the first instance of which started on JUN 26, about the time I changed the NagiosXI root password. The last successful perf graph was at 17:44, and the the error appears in the cron log at 18:25, and that was the moment all of our graphs died.
Jun 26 18:25:01 localhost crond[8325]: (root) PAM ERROR (Permission denied)
Jun 26 18:25:01 localhost crond[8325]: (root) FAILED to authorize user with PAM (Permission denied)
I also modified /etc/security/access.conf to deny root access from any sources not within our internal management network. Consequently, I commented out the line which gives root access to cron. I wasn't aware of the cron / mrtg relationship and the necessity for root access to cron until reading your thread.
Are you able to provide an example of an appropriate /etc/security/access.conf file which will accomplish the following:
1. allow nagios / mrtg to do what it needs with the least necessary privilege
2. restrict all other root access not needed
The default NagiosXI .OVA template has SSH / TTY access open to the world which we need to squelch, but in a way that doesn't break Nagios reporting. I took the following approach, which didnt work:
I am going to re-enable root access to cron by adding this to the access.conf:
Here is the output from the /var/log/cron which clued me in on all of this ...
I don't think posting the .rrd file will be necessary, since I am pretty sure things will start working again once root has regained access to cron. Will report back with findings in approx 30 minutes.
THANK YOU so much for pointing me int he right direction!!! It would be wonderful if Nagios could publish a post-installation hardening guide to take care of basic server hardening while giving consideration to Nagios inherent services (mrtg, MySQL, etc.)
# User "root" should get access from network 192.168.201.
# This term will be evaluated by string matching.
# comment: It might be better to use network/netmask instead.
# The same is 192.168.201.0/24 or 192.168.201.0/255.255.255.0
+:root:192.168.201.
# User "root" should be denied to get access from all other sources.
-:root:ALL
# User "root" should be allowed to get access via cron .. tty5 tty6.
+:root:cron crond :0 tty1 tty2 tty3 tty4 tty5 tty6
Jun 26 18:14:01 localhost CROND[20672]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:15:01 localhost CROND[26419]: (root) CMD (LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok --user=nagios --group=nagios --user=nagios --group=nagios)
Jun 26 18:15:01 localhost CROND[26421]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 26 18:15:01 localhost CROND[26420]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:15:01 localhost CROND[26424]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:15:01 localhost CROND[26427]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 26 18:15:01 localhost CROND[26422]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 26 18:15:01 localhost CROND[26426]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 26 18:15:01 localhost CROND[26436]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 26 18:15:01 localhost CROND[26437]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 26 18:15:01 localhost CROND[26432]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 26 18:15:01 localhost CROND[26434]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 26 18:15:01 localhost CROND[26435]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 26 18:15:01 localhost CROND[26433]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1)
Jun 26 18:16:01 localhost CROND[31655]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:16:01 localhost CROND[31671]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 26 18:16:01 localhost CROND[31672]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 26 18:16:01 localhost CROND[31674]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 26 18:16:01 localhost CROND[31677]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 26 18:16:01 localhost CROND[31679]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 26 18:16:01 localhost CROND[31680]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 26 18:16:01 localhost CROND[31683]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 26 18:16:01 localhost CROND[31685]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:16:01 localhost CROND[31684]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 26 18:16:01 localhost CROND[31688]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 26 18:17:01 localhost CROND[4760]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 26 18:17:01 localhost CROND[4761]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 26 18:17:01 localhost CROND[4762]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:17:01 localhost CROND[4766]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 26 18:17:01 localhost CROND[4765]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 26 18:17:01 localhost CROND[4768]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 26 18:17:01 localhost CROND[4769]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 26 18:17:01 localhost CROND[4774]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 26 18:17:01 localhost CROND[4773]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 26 18:17:01 localhost CROND[4776]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 26 18:17:01 localhost CROND[4775]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:18:01 localhost CROND[9685]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:18:01 localhost CROND[9687]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 26 18:18:01 localhost CROND[9688]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:18:01 localhost CROND[9689]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 26 18:18:01 localhost CROND[9691]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 26 18:18:01 localhost CROND[9692]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 26 18:18:01 localhost CROND[9697]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 26 18:18:01 localhost CROND[9698]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 26 18:18:01 localhost CROND[9700]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 26 18:18:01 localhost CROND[9703]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 26 18:18:01 localhost CROND[9707]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 26 18:19:01 localhost CROND[14706]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:19:01 localhost CROND[14707]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 26 18:19:01 localhost CROND[14711]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:19:01 localhost CROND[14709]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 26 18:19:01 localhost CROND[14710]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 26 18:19:01 localhost CROND[14715]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 26 18:19:01 localhost CROND[14716]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 26 18:19:01 localhost CROND[14719]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 26 18:19:01 localhost CROND[14722]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 26 18:19:01 localhost CROND[14720]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 26 18:19:01 localhost CROND[14723]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 26 18:20:01 localhost CROND[19948]: (root) CMD (LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lib/mrtg/mrtg.lock --confcache-file /var/lib/mrtg/mrtg.ok --user=nagios --group=nagios --user=nagios --group=nagios)
Jun 26 18:20:01 localhost CROND[19949]: (root) CMD (/usr/lib64/sa/sa1 1 1)
Jun 26 18:20:01 localhost CROND[19951]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 26 18:20:01 localhost CROND[19950]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:20:01 localhost CROND[19953]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 26 18:20:01 localhost CROND[19952]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 26 18:20:01 localhost CROND[19954]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 26 18:20:01 localhost CROND[19955]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/dbmaint.php >> /usr/local/nagiosxi/var/dbmaint.log 2>&1)
Jun 26 18:20:01 localhost CROND[19966]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 26 18:20:01 localhost CROND[19965]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 26 18:20:01 localhost CROND[19961]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 26 18:20:01 localhost CROND[19967]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 26 18:20:01 localhost CROND[19964]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:20:01 localhost CROND[19968]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 26 18:21:01 localhost CROND[23763]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:21:01 localhost CROND[23765]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:21:01 localhost CROND[23767]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 26 18:21:01 localhost CROND[23769]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 26 18:21:01 localhost CROND[23771]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 26 18:21:02 localhost CROND[23782]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 26 18:21:02 localhost CROND[23783]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 26 18:21:02 localhost CROND[23780]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 26 18:21:02 localhost CROND[23784]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 26 18:21:02 localhost CROND[23781]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 26 18:21:02 localhost CROND[23787]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 26 18:22:01 localhost CROND[27357]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 26 18:22:01 localhost CROND[27358]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 26 18:22:01 localhost CROND[27359]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 26 18:22:01 localhost CROND[27361]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 26 18:22:01 localhost CROND[27366]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 26 18:22:01 localhost CROND[27371]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 26 18:22:01 localhost CROND[27365]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:22:01 localhost CROND[27368]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 26 18:22:01 localhost CROND[27370]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 26 18:22:01 localhost CROND[27372]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:22:01 localhost CROND[27369]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 26 18:23:01 localhost CROND[31012]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:23:01 localhost CROND[31013]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 26 18:23:01 localhost CROND[31014]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 26 18:23:01 localhost CROND[31020]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 26 18:23:01 localhost CROND[31021]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 26 18:23:01 localhost CROND[31023]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 26 18:23:01 localhost CROND[31019]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:23:01 localhost CROND[31024]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 26 18:23:01 localhost CROND[31016]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 26 18:23:01 localhost CROND[31022]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 26 18:23:01 localhost CROND[31026]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 26 18:24:01 localhost CROND[3086]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Jun 26 18:24:01 localhost CROND[3088]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:24:01 localhost CROND[3089]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Jun 26 18:24:01 localhost CROND[3091]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
Jun 26 18:24:01 localhost CROND[3096]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Jun 26 18:24:01 localhost CROND[3099]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Jun 26 18:24:01 localhost CROND[3093]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Jun 26 18:24:01 localhost CROND[3098]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:24:01 localhost CROND[3097]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Jun 26 18:24:01 localhost CROND[3094]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Jun 26 18:24:01 localhost CROND[3100]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Jun 26 18:25:01 localhost CROND[8338]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results.log 2>&1)
Jun 26 18:25:01 localhost CROND[8341]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Jun 26 18:25:01 localhost CROND[8344]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php >> /usr/local/nagiosxi/var/nom.log 2>&1)
BOOM!!!
So, allowing root access to cron in the /etc/security/access.conf file did the trick.
All Performance Graphs and related Dashboards are updating now. This article was particularly helpful in deducing that PAM error in the cron log.
https://www.linuxquestions.org/question ... 175492110/
Thanks again!
Thanks again!
Great!
Locking thread
Locking thread
