Dears,
I need your help to know how I can install NRPE in offline server. This server has no internet access, so I can't install NRPE plugins and the pre-requisites online.
Can I make one offline NRPE installation file contains all required plugins, packages and the pre-requisites?
BR
NRPE offline installation
Re: NRPE offline installation
Hello BR,
NRPE - How To Install NRPE v3 From Source
Take a look at the following document as it contains all of the packages per operating system required to compile NRPE.Can I make one offline NRPE installation file contains all required plugins, packages and the pre-requisites?
Thank you very much for the support.benjaminsmith wrote:Hello BR,Take a look at the following document as it contains all of the packages per operating system required to compile NRPE.Can I make one offline NRPE installation file contains all required plugins, packages and the pre-requisites?
I read that it contains the required dependencies, but it may try to update the installed dependencies. This is also installation from source, and in some servers I'm not allowed to install the development dependencies to compile NRPE, so I need also to do the installation by installing RPM packages instead of using compilation.
Thank you in advance.
Unfortunately, we do not provide NRPE RPM packages. Thank you!
Thank you so much for the clarification.lmiltchev wrote:Unfortunately, we do not provide NRPE RPM packages. Thank you!
You are welcome! Sorry for the inconvenience! I am closing this topic. Thanks!
