Template use
seaward1983
Template use
Post by seaward1983 »
I used the Windows SNMP monitoring Wizard for domain controllers, and saved it as a template. I've been searching around - and I can't figure out now, how to use the template - when I rerun the Windows SNMP monitoring Wizard, it doesn't ask for a template. I'm sure I'm missing something...
benjaminsmith
Re: Template use
Post by benjaminsmith »
Hello @seaward1983,
The templates for wizards are used for steps 3-5 of the wizard and are not quite the same as templates defined in the Core Configuration Manager. When you get to this point, you'll be presented with a Finish with Template button.
Documentation: Understanding And Using Configuration Wizards In Nagios XI
