Hi Team,
While we are checking the time syn we are getting the return code 128. Please find the below and help us why we are getting 128 error.
root@nagih libexec]# ./check_nrpe -H XXXX -c check_time -a ntp.test.com 5 20
The command (check_time) returned an invalid return code: 128
we are able to telnet 5666 port to remote server.
The command (check_time) returned an invalid return code:128
Re: The command (check_time) returned an invalid return code
Does the command work when you run it locally on the client (remote machine)?
Can you show us how the check_time command is defined on the client?
I tried the following setup, which worked for me:
In nrpe.cfg on the remote machine:
From the Nagios XI server:
./check_time -H ntp.test.com -w 5 -c 20
command[check_time]=/usr/local/nagios/libexec/check_time -H $ARG1$ -w $ARG2$ -c $ARG3$
[root@main-nagios-xi libexec]# ./check_nrpe -H x.x.x.x -c check_time -a time.nist.gov 5 20
TIME OK - 0 second time difference|time=0s;;;0 offset=0s;5;20;0
Please find the below details which we added in nsclient.ini and Please tell us why we get 128 return code. Please don't send link for return code actually i am not understanding. If we get this type of messages 128 what we need to do from client end.
nsclient.ini config below
; WRAPPED SCRIPT - A wrapped script defenitions
check_time = fair\\check_time.vbs %ARGS%
Command in nagios-server:
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 120 -c $ARG1$ $ARG2$ $ARG3$
/usr/local/nagios/libexec/check_nrpe -H XXX -t 120 -c check_time -a ntp.test.com 5 20
But we are getting the output for some other server
/usr/local/nagios/libexec/check_nrpe -H XXXX-t 120 -c check_time -a ntp.test.com 5 20
NTP OK: Offset -0.7279992 secs|'offset'=-0.72799s;5;20
So, I didn't realize that you are using NSClient++... This would be a bit different, but we can make it work.
1. Can you confirm that you are using the plugin below?
https://exchange.nagios.org/directory/U ... s)/details
2. If you are using it, then you would need to set it up differently. Place the plugin in the NSClient++ scripts directory. Remove the line that you have under the [/settings/external scripts/wrapped scripts] section.
Add the following line under the [/settings/external scripts/scripts] section:
Save, exit, and restart NSClient++ service, so that changes can take effect. Test your check from the command line.
Example:
3. If you are NOT using this plugin, but some other, "custom" one, please upload it on the forum, so that we can test it in-house.
check_time = cscript.exe //T:30 //NoLogo scripts\check_time.vbs $ARG1$
Example:
[root@main-nagios-xi libexec]# ./check_nrpe -H x.x.x.x -c check_time -a 'pool.ntp.org,time.nist.gov 2 5'
NTP OK: Offset +0.2097703 secs|'offset'=0.20977s;2;5
