After upgrading from R1.2B to R1.2C my Windows Server and Network Switch wizards are not creating all the services I select.
For instance I select the Switch wizard and scan interfaces and select a couple to monitor - the wizard completes and settings are saved. I find that only the ping service is created. When running the windows server wizard only the ping, cpu and memory usage services are created.
I see the following error in my http log:
[Tue Jul 27 15:53:31 2010] [error] [client x.x.x.x] PHP Warning: htmlentities() expects parameter 1 to be string, array given in /usr/local/nagiosxi/html/includes/utils.inc.php on line 109, referer: http://nagiosxi/nagiosxi/config/monitoringwizard.php
[Tue Jul 27 15:53:37 2010] [error] [client x.x.x.x] PHP Warning: Invalid argument supplied for foreach() in /usr/local/nagiosxi/html/includes/configwizards/switch/switch.inc.php on line 533, referer: http://nagiosxi/nagiosxi/config/monitoringwizard.php
[Tue Jul 27 15:53:38 2010] [error] [client 127.0.0.1] PHP Fatal error: Call to a member function setVariable() on a non-object in /var/www/html/nagiosql/index.php on line 103
[Tue Jul 27 15:53:40 2010] [error] [client 127.0.0.1] PHP Fatal error: Call to a member function setVariable() on a non-object in /var/www/html/nagiosql/index.php on line 103
Any ideas?
Chris
Problems with wizards since 1.2B => 1.2C upgrade
Re: Problems with wizards since 1.2B => 1.2C upgrade
This is a known issue corrected in D.
Great thanks for the info. Is there an approx release date for D?
- Box293
- Too Basu
It's available for download now, was only released yesterday.
thanks that solved the issue.
