I'm evaluating NagiosXI for use in our environment and need some help. I'm trying to find documentation on Nagios XI Performance Graph configurations. I want to use this feature to help with capacity analysis. Right now I can see 4-24 hours of data. I dont have anything after that. How do I get the week and month views to work? Is this a place to configure how much data is stored for performance?
Thank you for your help,
Patrick
Performance graphs only have 24hrs of info
Re: Performance graphs only have 24hrs of info
How long have you had the Nagios server up and running? If I remember correctly the longer performance graph views are visible once there is actually graphing data for them. The links for the week and month views should work once the server has data for it.
Its been a week, but many hosts/services have been rebuilt multiple times. So I probably need to wait a bit longer. Thank you
- Box293
- Too Basu
Please explain in more detail. I.E. rebuilt means you've changed the names of services and hosts after they were created with the wizard?ppresto wrote:but many hosts/services have been rebuilt multiple times
