Notifications on Openfire?
Hey guys,
I'm actual running Nagios Core and Openfire on openSUSE and now I'd like to send notifications (if a problem appears) in the Openfire-Chat.
I did alot of research, found several Jabber Notifications, BUT they were all out of date, and no one of them got any Documentation.
So my question is: is it possible to connect Nagios and Openfire? If yes, do I only need the check_jabber plugin? I know jabber is another call for xmpp, but xmpp is not equal Openfire ... right ?!
I'd be pleased if someone could help me to find (and maybe to install) such a function.
Regards
Regards
Re: Notifications on Openfire?
Hi Yaerox,
Just to confirm, are you trying to send Nagios notifications to an xmpp chat room/user? (i.e. Nagios XMPP notifications)
If so, you should check out Nagibot, it's what I use for this functionality and it's quite good, no real problems with it since I set it up.
Below are the two pages I used for this.
Good luck!
Kind Regards,
Gary Shergill
The first link is in German. I don't know German, but the steps seemed simple enough to follow.
Good luck!
Kind Regards,
Gary Shergill
Hi gshergill,
yeah, I want Nagios to send notifications to an Openfire chat room/user.
Ill try this out. The first link is pretty nice, I'm german so, I'll give it a try now
Thanks alot.
Thanks alot.
Actual trying to install NagiBot - no problems until: start nagiBot.
I'm only getting:
nagibot 0.8 starting ...
using config file from commandline
Trying to connect ...
Opening fifo for reading ...
connected to example.com:5222
and the following is still missing:
Connected as nagibot@example.com/nagibot.pl
Setting presence ...
Joining rooms (if any) ...
Register room message handler ...
Starting idle timer (300 seconds).
The Nagibot user doesnt even got online ...
Thanks in advice.
I'm only getting:
Thanks in advice.
Can you post your nagibot config file and the nagios service check definition you are using for it?
Yeah but unfortunately on monday. Actual on my weekend i have no chance do get on the Computer right now :/ sry but i really appreciate your help and hope you will still help me on monday.
Thanks alot.
Regards.
Thanks alot.
Regards.
I've used the posted .pdf of gshergill.
Starting Nagibot:
Here my configs...
nagibot.conf:
commands.cfg
localhost.cfg:
Regards
Starting Nagibot:
nagibot.pl -vvv -c /usr/local/src/nagibot/nagibot.conf nagibot@IP_ADRESS
nagibot 0.8.3 starting ...
connected to IP_ADRESS:5222
Disconnected from IP_ADRESS:5222: Error on connection to IP_ADRESS:5222: Protocol error
nagibot.conf:
# Rooms to join
nagibot-room@conference.SERVER_ADRESS: nagibot
# JIDs to inform (none in my case)
# Configuration
nagios_status_log_file: /usr/local/nagios/var/status.dat
nagios_msg_fifo: /usr/local/nagios/var/rw/nagibot.fifo
bot_status: available
bot_status_text: I am a bot ...
bot_status_priority: 10
password: MY_PASSWORD_SET_FOR_THE_NAGIOS_USER_IN_OPENFIRE
command_name notify-host-by-pipe
command_line /usr/bin/printf "%b" \
"*$NOTIFICATIONTYPE$* $HOSTNAME$ is $HOSTSTATE$\n" \
command_name notify-service-by-pipe
"*$NOTIFICATIONTYPE$* $SERVICEDESC$ on $HOSTALIAS$ $SERVICESTATE$\n" \
use local-service
host_name localhost
service_description FTP
check_command notify-service-by-pipe
Regards
Hi Yaerox,
The problem seems to be with connecting to the server;
Not sure why that's coming up, I never had that appear.
Personally I use the FQDN when connecting;
Using the IP there had some errors for me before (different to yours).
Kind Regards,
Gary Shergill
nagibot.pl -vvv -c /usr/local/src/nagibot/nagibot.conf nagibot@openfire.example.com
Kind Regards,
Gary Shergill
#edited post:
Hi gshergill,
I'm running Openfire and Nagios on an openSUSE VM in a domain ... on Openfire-User-Administration NagiBot got the JID: nagibot@IP_ADRESS.
If I try hostname -f I get "hostname: Name or service not known"
hostname is giving me a linux-wnrb ...
hosts: 127.0.0.1 localhost
Starting Nagibot @localhost instead of IP_ADRESS gives me the same result :/
resolv.conf:
search the.name.of.my.domain
nameserver an_adress_of_my_domain
Regards
Hi gshergill,
resolv.conf:
Regards
Hi Yaerox,
Sorry, didn't see the bit about openSUSE, never heard of it to be honest (I just use seperate VMs, one with Openfire and the rest with Nagios).
Sorry can't be much more help.
Kind Regards,
Gary Shergill
Kind Regards,
Gary Shergill
