NRPE issue
abrist
Red Shirt
Re: NRPE issue
Post by abrist »
Well, you have 1 plugin working through nrpe (check_apt)? I will have to peruse your configs this weeksend.
jiggityjog
Re: NRPE issue
Post by jiggityjog »
ALRIGHT. I got it. Noticed what this fellow did: http://stackoverflow.com/questions/1021 ... n-the-term
If anyone's been following, initially, I couldn't load the configuration I had set due to a duplicate command definition.
        command_name check_nrpe
	command_line	$USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
which became
and the solution!
        command_name check_nrpe_cart_OR_ANYTHING_DISTINGUISHABLE
And then use that command_name correspondingly in the services. Boy do I feel silly. Thanks for all the help!
Re: NRPE issue
I'm glad you got your issue resolved!
