Regex
sysmo
Regex
Post by sysmo »
I'm kind of struggeling with the regex syntax.
i;ve managed te obviouse "all" : .*
and grouping by first characters of the name : ^Site-1.*
but i'm kind of lost on the rest. eg. how to exclude just two hosts from the .* expression or an regex to match characters in the middle (eg regex for 'router' to match the hosts Site1-router-881 and Site-2-router-887)
Is there an simple tutorial for regex as nagios uses it?
yancy
Re: Regex
Post by yancy »
sysmo,
Are you using regular expressions to define hostgroups?
a great resource for regular expressions can be found here:
http://www.regular-expressions.info
-Yancy
