NRPE check_windows_time
Re: NRPE check_windows_time
Post by slansing »
It looks as though you have the handler defined properly in your nsclient.ini file, though it needs to be moved to the external scripts section, the header of this section is:
[External Scripts]
Depending on how the external script works you may need to add $ARG1$ after the definition as you are passing an argument.
alceryes
Post by alceryes »
The $ARG1$ was it! Didn't have to move it to [External Scripts].
Thx a million!!!
Post by slansing »
Great! Thanks for letting us know what resolved this!
