NRPE check_windows_time
I've got NRPE setup and have a few remote commands checking other things but for some reason I can't get the check_windows_time batch file to run. It's supposed to be run with arguments (check_windows_time pool.ntp.org 120 300) but every time I run it in Nagios with NRPE I just get the usage/help for it as the output - like it didn't take the arguments. If I execute it on the windows server it gives the correct output. I've tried different iterations (using -a) but am stuck.
Any advise would be greatly appreciated. TIA!
Re: NRPE check_windows_time
Can you share your command definition with us? It should be along the lines of:
And then can you also share how you have this command defined to be called in the NSC/NSClient.ini file on your windows system? Thanks!
/usr/local/nagios/libexec/check_nrpe -H host.ip.here -p 5666 -c check_windows_time -a
Post the current versions of the service check and command in the nagios config files and the remote host's nrpe,cfg. We will try to fix it up from there.
Thx guys.
I haven't even defined the service check yet as I am trying to run in via command first.
Here is the defined command -
command_name check_windows_time
command_line $USER1$/check_windows_time -H $HOSTADDRESS$ $ARG1$ $ARG2$
The command I am running is -
root@------:/usr/local/nagios/etc/objects# ./check_nrpe -H 192.168.1.1 -p 5666 -c check_windows_time -a pool.ntp.org 120 300
I know it's executing the command on the remote server but it's just giving me the help text, meaning it's not running it with the arguments.
Make sure in the NSC.ini you have:
After modifying this line, you need to restart the nsclient++ service, so that the changes can take effect.
allow_arguments=1
I already have the 'allow_arguments=1' line and have restarted the nagios service.
Thx
Thx
Try wrapping your argument in single quotes:
./check_nrpe -H 192.168.1.1 -p 5666 -c check_windows_time -a 'pool.ntp.org 120 300'
Same result - help text.
Could you post your full nsclient config file in code wraps?
Here you go, thx! (sanitized with ++++++++++++++)
[modules]
NRPEListener.dll
NSClientListener.dll
NSCAAgent.dll
CheckWMI.dll
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
CheckEventLog.dll
CheckHelpers.dll
;# NSCLIENT++ MODULES
;# A list with DLLs to load at startup.
; You will need to enable some of these for NSClient++ to work.
; * N O T I C E ! ! ! - Y O U H A V E T O E D I T T H I S *
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
NRPEListener.dll
SysTray.dll
CheckEventLog.dll
CheckHelpers.dll
CheckWMI.dll
; Script to check external scripts and/or internal aliases.
CheckExternalScripts.dll
; NSCA Agent if you enable this NSClient++ will talk to NSCA hosts repeatedly (so dont ;enable unless you want to use NSCA)
;NSCAAgent.dll
; LUA script module used to write your own "check deamon".
;LUAScript.dll
; RemoteConfiguration IS AN EXTREM EARLY IDEA SO DONT USE FOR PRODUCTION ENVIROMNEMTS!
;RemoteConfiguration.dll
; Check other hosts through NRPE extreme beta and probably a bit dangerous! :)
;NRPEClient.dll
; Extreamly early beta of a task-schedule checker
;CheckTaskSched.dll
[Settings]
;# OBFUSCATED PASSWORD
; This is the same as the password option but here you can store the password in an obfuscated manner.
; *NOTICE* obfuscation is *NOT* the same as encryption, someone with access to this file can still figure out the
; password. Its just a bit harder to do it at first glance.
;obfuscated_password=++++++++++++++
;# PASSWORD
; This is the password (-s) that is required to access NSClient remotely. If you leave this blank everyone will be able to access the daemon remotly.
;password=secret-password
;# ALLOWED HOST ADDRESSES
; This is a comma-delimited list of IP address of hosts that are allowed to talk to the all daemons.
; If leave this blank anyone can access the deamon remotly (NSClient still requires a valid password).
; The syntax is host or ip/mask so 192.168.0.0/24 will allow anyone on that subnet access
;allowed_hosts=127.0.0.1/32
;# USE THIS FILE
; Use the INI file as opposed to the registry if this is 0 and the use_reg in the registry is set to 1
; the registry will be used instead.
use_file=1
allowed_hosts=++++++++++++++
; # USE SHARED MEMORY CHANNELS
; This is the "new" way for using the system tray based on an IPC framework on top shared memmory channels and events.
; It is brand new and (probably has bugs) so dont enable this unless for testing!
; If set to 1 shared channels will be created and system tray icons created and such and such...
;shared_session=0
[log]
;# LOG DEBUG
; Set to 1 if you want debug message printed in the log file (debug messages are always printed to stdout when run with -test)
;debug=1
;# LOG FILE
; The file to print log statements to
;file=nsclient.log
;# LOG DATE MASK
; The format to for the date/time part of the log entry written to file.
;date_mask=%Y-%m-%d %H:%M:%S
;# LOG ROOT FOLDER
; The root folder to use for logging.
; exe = the folder where the executable is located
; local-app-data = local application data (probably a better choice then the old default)
;root_folder=exe
[NSClient]
; This is a comma-delimited list of IP address of hosts that are allowed to talk to NSClient deamon.
; If you leave this blank the global version will be used instead.
;allowed_hosts=
;# NSCLIENT PORT NUMBER
; This is the port the NSClientListener.dll will listen to.
port=1248
;# BIND TO ADDRESS
; Allows you to bind server to a specific local address. This has to be a dotted ip adress not a hostname.
; Leaving this blank will bind to all avalible IP adresses.
;bind_to_address=
;# SOCKET TIMEOUT
; Timeout when reading packets on incoming sockets. If the data has not arrived withint this time we will bail out.
;socket_timeout=30
[NRPE]
;# NRPE PORT NUMBER
; This is the port the NRPEListener.dll will listen to.
port=5666
;# COMMAND TIMEOUT
; This specifies the maximum number of seconds that the NRPE daemon will allow plug-ins to finish executing before killing them off.
;command_timeout=60
;# COMMAND ARGUMENT PROCESSING
; This option determines whether or not the NRPE daemon will allow clients to specify arguments to commands that are executed.
allow_arguments=1
;# COMMAND ALLOW NASTY META CHARS
; This option determines whether or not the NRPE daemon will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow_nasty_meta_chars=1
;# USE SSL SOCKET
; This option controls if SSL should be used on the socket.
;use_ssl=1
;# BIND TO ADDRESS
; bind_to_address=
; This is a comma-delimited list of IP address of hosts that are allowed to talk to NRPE deamon.
;# SCRIPT DIRECTORY
; All files in this directory will become check commands.
; *WARNING* This is undoubtedly dangerous so use with care!
;script_dir=scripts\
;# SOCKET TIMEOUT
;socket_timeout=30
[Check System]
;# CPU BUFFER SIZE
; Can be anything ranging from 1s (for 1 second) to 10w for 10 weeks. Notice that a larger buffer will waste memory
; so don't use a larger buffer then you need (ie. the longest check you do +1).
;CPUBufferSize=1h
;# CHECK RESOLUTION
; The resolution to check values (currently only CPU).
; The value is entered in 1/10:th of a second and the default is 10 (which means ones every second)
;CheckResolution=10
;# CHECK ALL SERVICES
; Configure how to check services when a CheckAll is performed.
; ...=started means services in that class *has* to be running.
; ...=stopped means services in that class has to be stopped.
; ...=ignored means services in this class will be ignored.
;check_all_services[SERVICE_BOOT_START]=ignored
;check_all_services[SERVICE_SYSTEM_START]=ignored
;check_all_services[SERVICE_AUTO_START]=started
;check_all_services[SERVICE_DEMAND_START]=ignored
;check_all_services[SERVICE_DISABLED]=stopped
[External Script]
;# COMMAND TIMEOUT
;command_timeout=60
allow_arguments=1
;# SCRIPT DIRECTORY
;script_dir=c:\my\script\dir
[External Scripts]
;check_es_long=scripts\long.bat
;check_es_ok=scripts\ok.bat
;check_es_nok=scripts\nok.bat
;check_vbs_sample=cscript.exe //T:30 //NoLogo scripts\check_vb.vbs
;check_powershell_warn=cmd /c echo scripts\powershell.ps1 | powershell.exe -command -
[External Alias]
alias_cpu=checkCPU warn=80 crit=90 time=5m time=1m time=30s
alias_cpu_ex=checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
alias_disk=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
alias_service=checkServiceState CheckAll
alias_process=checkProcState $ARG1$=started
alias_mem=checkMem MaxWarn=80% MaxCrit=90% ShowAll type=physical
alias_up=checkUpTime MinWarn=1d MinWarn=1h
alias_file_age=checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
alias_file_size=checkFile2 filter=out "file=$ARG1$" filter-size=>$ARG2$ MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%"
alias_file_size_in_dir=checkFile2 filter=out pattern=*.txt "file=$ARG1$" filter-size=>$ARG2$ MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%"
alias_event_log=CheckEventLog file=application file=system filter=new filter=out MaxWarn=1 MaxCrit=1 filter-generated=>2d filter-severity==success filter-severity==informational truncate=1023 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
alias_event_log2=CheckEventLog file=application file=system filter=new filter=in MaxWarn=1 MaxCrit=1 filter+generated=<2d "filter+eventSource==Service Control Manager" filter+severity==error truncate=1023 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
check_ok=CheckOK Everything is fine!
; [includes]
;# The order when used is "reversed" thus the last included file will be "first"
;# Included files can include other files (be carefull only do basic recursive checking)
; myotherfile.ini
; real.ini
[NSCA Agent]
;# CHECK INTERVALL (in seconds)
; How often we should run the checks and submit the results.
;interval=5
;# ENCRYPTION METHOD
; This option determines the method by which the send_nsca client will encrypt the packets it sends
; to the nsca daemon. The encryption method you choose will be a balance between security and
; performance, as strong encryption methods consume more processor resources.
; You should evaluate your security needs when choosing an encryption method.
; Note: The encryption method you specify here must match the decryption method the nsca daemon uses
; (as specified in the nsca.cfg file)!!
; Values:
; 0 = None (Do NOT use this option)
; 1 = Simple XOR (No security, just obfuscation, but very fast)
; 2 = DES
; 3 = 3DES (Triple DES)
; 4 = CAST-128
; 6 = xTEA
; 8 = BLOWFISH
; 9 = TWOFISH
; 11 = RC2
; 14 = RIJNDAEL-128 (AES)
; 20 = SERPENT
;encryption_method=14
;# ENCRYPTION PASSWORD
; This is the password/passphrase that should be used to encrypt the sent packets.
;password=
;# BIND TO ADDRESS
; Leaving this blank will bind to "one" local interface.
; -- not supported as of now --
;bind_to_address=
;# LOCAL HOST NAME
; The name of this host (if empty "computername" will be used.
;hostname=
;# NAGIOS SERVER ADDRESS
; The address to the nagios server to submit results to.
;nsca_host=++++++++++++++
;# NAGIOS SERVER PORT
; The port to the nagios server to submit results to.
;nsca_port=5667
;# CHECK COMMAND LIST
; The checks to run everytime we submit results back to nagios
; Any command(alias/key) starting with a host_ is sent as HOST_COMMAND others are sent as SERVICE_COMMANDS
; where the alias/key is used as service name.
[NSCA Commands]
;my_cpu_check=checkCPU warn=80 crit=90 time=20m time=10s time=4
;my_mem_check=checkMem MaxWarn=80% MaxCrit=90% ShowAll type=page
;my_svc_check=checkServiceState CheckAll exclude=wampmysqld exclude=MpfService
;host_check=check_ok
;# REMOTE NRPE PROXY COMMANDS
; A list of commands that check other hosts.
; Used by the NRPECLient module
[NRPE Handlers]
check_other=-H ++++++++++++++ -p 5666 -c remote_command -a arguments
check_adhealth=C:\Program Files\NSClient++\scripts\Check_AD.exe
check_windows_time=C:\Program Files\NSClient++\scripts\check_windows_time.bat
;# LUA SCRIPT SECTION
; A list of all Lua scripts to load.
;[LUA Scripts]
;scripts\test.lua
