I have a really strange problem. I hope u guy's can help me out. I have to authorisations methods in my nagios.conf. The one is NTML and the other one is guest account.
The problem is that i get prompt whith authentication when i want to use the guest account.
# SAMPLE CONFIG SNIPPETS FOR APACHE WEB SERVER
# Last Modified: 11-26-2005
# This file contains examples of entries that need
# to be incorporated into your Apache web server
# configuration file. Customize the paths, etc. as
# needed to fit your system.
Options ExecCGI
AllowOverride None
AuthName "NTLM Authentication thingy"
NTLMAuth on
NegotiateAuth on
NTLMAuthHelper "/usr/bin/ntlm_auth --helper-protocol=squid-2.5-ntlmssp"
NegotiateAuthHelper "/usr/bin/ntlm_auth --helper-protocol=gss-spnego"
NTLMBasicAuthoritative on
AuthType NTLM
AuthType Negotiate
require valid-user
</Directory>
Alias /nagios "/usr/local/nagios/share"
<Directory "/usr/local/nagios/share">
Options None
AllowOverride None
NTLMAuth on
NegotiateAuth on
AuthType NTLM
AuthType Negotiate
require valid-user
</Directory>
# Ensure that Apache listens on port 80
Listen 8080
# Listen for virtual host requests on all IP addresses
NameVirtualHost *:8080
<VirtualHost *:8080>
DocumentRoot /usr/local/nagios/share
ServerName monnagios.domain.local
Options ExecCGI
AllowOverride None
Order allow,deny
Allow from all
</Directory>
Options None
AllowOverride None
Order allow,deny
Allow from all
</Directory>
</VirtualHost>
So when i open up internet explorer(http://monnagios:8080/nagios i get prompt. It should not prompt me and use the guest account. DNS is working. I checked the cgi.cfg and there i added:
ruffsense wrote:
No this will not let the guest user log automatically. I want to be prompt one time and then IE9 needs to keep the credentials.
Basic auth should only prompt for the password one time. Afterwards, it is up to the browser/user to keep the credentials as the credentials are stored in the browser cache. If your browser clears the cache on close, automatically clears, or is set to not cache, your password will have to be reentered after your session closes or timeouts.
Options ExecCGI
AllowOverride None
Order allow,deny
Allow from all
</Directory>
Options None
AllowOverride None
Order allow,deny
Allow from all
</Directory>
If you comment out the first section of the vhosts file (NTLM auth), do you still get prompted for auth when you browse to 8080? (make sure to restart the apache server after you comment out the NTLM directory declarations).
When it is prompting, is it working with guest and no password or must you use an NTLM authenticated user?
