Ubuntu 12.04 LTS and Nagios
Hi Guys, this is my first post on the forum, I hope I make this post in the correct section.
I have installed Nagios on my Ubuntu server.
Nagios is running, Apache also is running.
When I want to monitor a website of mine Nagios says:
Host State Information
Host Status: DOWN
(for 0d 0h 30m 44s)
Status Information: PING CRITICAL - Packet loss = 100%
Performance Data: rta=5000.000000ms;5000.000000;5000.000000;0.000000 pl=100%;100;100;0
Current Attempt: 1/10 (HARD state)
Last Check Time: 2013-08-06 19:45:21
Check Type: ACTIVE
Check Latency / Duration: 0.000 / 10.018 seconds
Next Scheduled Active Check: 2013-08-06 19:50:31
Last State Change: 2013-08-06 19:19:31
Last Notification: 2013-08-06 19:19:31 (notification 1)
Is This Host Flapping? NO
(4.01% state change)
In Scheduled Downtime? NO
Last Update: 2013-08-06 19:50:11 ( 0d 0h 0m 4s ago)
Active Checks: ENABLED
Passive Checks: ENABLED
Obsessing: ENABLED
Notifications: ENABLED
Event Handler: ENABLED
Flap Detection: ENABLE
The site is up and running, it does the same for other sites, including Google.com
When I enter the check_http command, Ubuntu states that the command is not found.
LS from plugins folder:
root@h2200554:/etc/nagios3/conf.d# ls
contacts_nagios2.cfg generic-service_nagios2.cfg services_nagios2.cfg
extinfo_nagios2.cfg hostgroups_nagios2.cfg test-google.cfg
generic-host_nagios2.cfg localhost_nagios2.cfg timeperiods_nagios2.cfg
Cat from test-google.cfg
root@h2200554:/etc/nagios3/conf.d# cat test-google.cfg
use generic-host
host_name google
alias google
address google.com
host_name google
service_description HTTP
check_command check_http
What is the cause of this problem and how can I fix this?
Your help is higly appreciated.
Edit:
Figured out how I can run a plugin from the CLI.
root@h2200554:~# cd /usr/lib/nagios/plugins
root@h2200554:/usr/lib/nagios/plugins# ./check_http -I http://www.google.com
HTTP OK: HTTP/1.0 302 Found - 1002 bytes in 0,062 second response time |time=0,062269s;;;0,000000 size=1002B;;;0
So if this is working, why is it not working in Nagios?
Host Status: DOWN
(for 0d 0h 30m 44s)
Check Type: ACTIVE
Obsessing: ENABLED
use generic-host
host_name google
alias google
address google.com
host_name google
Edit:
Re: Ubuntu 12.04 LTS and Nagios
What are the permissions on check_http?
Can you run the check as nagios user?
What is the output of the following command?
ls -la /usr/lib/nagios/plugins/check_http
su - nagios -c "/usr/lib/nagios/plugins/check_http -I google.com"
grep nag /etc/group
There could be more than one issue, but I noticed rather quickly that your listing of the config directory was missing a commands.cfg file. This file should have all of the "vanilla" command definitions, including check_http. Maybe it is located somewhere else?
EDIT: This file name may be different in your environment. You may also want to grep the config directory for check_http to see if you have a definition in another file:
find / -name commands.cfg
grep -5 check_http /etc/nagios3/conf.d/*
I am kinda new to Linux Ubuntu, so the output below doesn''t say everything to me.
Is the output below something you can identify the problem with?
Strange enough no output here.
root@h2200554:~# su - nagios -c "/usr/lib/nagios/plugins/check_http -I google.com"
root@h2200554:~#
root@h2200554:~# grep nag /etc/group
nagios127:www-data
root@h2200554:~# ls -la /usr/lib/nagios/plugins/check_http
-rwxr-xr-x 1 root root 146656 jul 5 11:13 /usr/lib/nagios/plugins/check_http
root@h2200554:~#
root@h2200554:~# find / -name commands.cfg
/usr/share/doc/nagios3-common/examples/commands.cfg
/usr/share/doc/nagios3-common/examples/template-object/commands.cfg
/etc/nagios3/commands.cfg
root@h2200554:~#
Thanks for your help.
root@h2200554:~#
nagios127:www-data
root@h2200554:~#
root@h2200554:~#
You forgot to run the last command as requested by abrist:
In addition to this, run the following command and show the output:
Show us the check_http command definition that you have in "/etc/nagios3/commands.cfg".
The "nagios" user is not part the the "nagios" group - only apache is, so run the following command to add it:
grep commands.cfg /etc/nagios3/nagios.cfg
useradd -G nagios nagios
Whoops sorry:
root@h2200554:~# grep -5 check_http /etc/nagios3/conf.d/*
/etc/nagios3/conf.d/services_nagios2.cfg-# check that web services are running
/etc/nagios3/conf.d/services_nagios2.cfg-define service {
/etc/nagios3/conf.d/services_nagios2.cfg- hostgroup_name http-servers
/etc/nagios3/conf.d/services_nagios2.cfg- service_description HTTP
/etc/nagios3/conf.d/services_nagios2.cfg: check_command check_http
/etc/nagios3/conf.d/services_nagios2.cfg- use generic-service
/etc/nagios3/conf.d/services_nagios2.cfg- notification_interval 0 ; set > 0 if you want to be renotified
/etc/nagios3/conf.d/services_nagios2.cfg-}
/etc/nagios3/conf.d/services_nagios2.cfg-# check that ssh services are running
/etc/nagios3/conf.d/test.cfg-
/etc/nagios3/conf.d/test.cfg-define service{
/etc/nagios3/conf.d/test.cfg-use generic-service
/etc/nagios3/conf.d/test.cfg-host_name google
/etc/nagios3/conf.d/test.cfg-service_description HTTP
/etc/nagios3/conf.d/test.cfg:check_command check_http
/etc/nagios3/conf.d/test.cfg-}
root@h2200554:~#
root@h2200554:~# grep commands.cfg /etc/nagios3/nagios.cfg
cfg_file=/etc/nagios3/commands.cfg
#cfg_file=/etc/nagios3/objects/commands.cfg
root@h2200554:~#
When trying to enter the last command I got this output:
root@h2200554:~# useradd -G nagios nagios
useradd: user 'nagios' already exists
And at last, I checked the config but didnt see anything regarding HTTP, maybe this is the issue?
root@h2200554:/etc/nagios3# cat commands.cfg
# COMMANDS.CFG - SAMPLE COMMAND DEFINITIONS FOR NAGIOS
# NOTIFICATION COMMANDS
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHos t: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nS ervice: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDAT ETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /usr/bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOS TALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
# HOST CHECK COMMANDS
# On Debian, check-host-alive is being defined from within the
# nagios-plugins-basic package
# PERFORMANCE DATA COMMANDS
# 'process-host-perfdata' command definition
command_name process-host-perfdata
command_line /usr/bin/printf "%b" "$LASTHOSTCHECK$\t$HOSTNAME$\t$HOSTSTATE$\t$HOSTATTEMPT$\t$HOSTST ATETYPE$\t$HOSTEXECUTIONTIME$\t$HOSTOUTPUT$\t$HOSTPERFDATA$\n" >> /var/lib/nagios3/host-perfdata.out
# 'process-service-perfdata' command definition
command_name process-service-perfdata
command_line /usr/bin/printf "%b" "$LASTSERVICECHECK$\t$HOSTNAME$\t$SERVICEDESC$\t$SERVICESTATE$\t$ SERVICEATTEMPT$\t$SERVICESTATETYPE$\t$SERVICEEXECUTIONTIME$\t$SERVICELATENCY$\t$SERVICEOUTPUT$\t$SERVICEPERFDA TA$\n" >> /var/lib/nagios3/service-perfdata.out
root@h2200554:~#
root@h2200554:~#
Looks like you are most definitely missing a command definition for check_http. It may be different depending on your environment, but the following is the default definition:
command_name check_http
command_line $USER1$/check_http -I $HOSTADDRESS$ $ARG1$
I have added this to my /etc/nagios-plugins/config/http.cfg file.
But when I restart Nagios Core I receive the message:
Processing object config file '/etc/nagios-plugins/config/http.cfg'...
Warning: Duplicate definition found for command 'check_http' (config file '/etc/nagios-plugins/config/http.cfg', starting on line 2)
Error: Could not add object property in file '/etc/nagios-plugins/config/http.cfg' on line 3.
* errors in config!
What in the world could be causing this? Did I place the text in the wrong file?
* errors in config!
Edit: my mistake, I placed the text in /etc/nagios3/commands.cfg instead of stated above.
Nope, it looks like that command is defined in the nagios plugins config. Interesting though, as you, earlier in this thread, were receiving an error relating to check_http missing. Did you install the nagios-plugins pack after attempting to set up the check?
