lookup device-id failed: Physical Memory
tmeto
Post by tmeto »
hi!
I'm having trouble with a check on a machine with windows 2000. The machine is virtualized and has 2g ram, but at check shows me this error "lookup failed device-id: Physical Memory" and I dont know that can be ...
any ideas?
Re: lookup device-id failed: Physical Memory
Post by slansing »
What check are you running? Can you also show us the command definition and let us know what the command that is actually being run looks like?
tmeto
Post by tmeto »
this is what you want to see?
command_name check_disk_snmp
command_line /usr/bin/perl $USER1$/check_disk_snmp.pl -H $HOSTADDRESS$ -s $ARG1$ -d $ARG2$ -u $ARG3$ -w $ARG4$ -c $ARG5$
Post by slansing »
Yes, can you also share the command definition as it appears in your service's .cfg file? So we can see what you are using for arguments?
tmeto
Post by tmeto »
sorry, bad command. :mrgreen:
hostgroup_name COAATM-CHECK
service_description check memoria
check_command check_winmem_snmp!nagiosica!MB!90%!99%
and ....
command_name check_winmem_snmp
command_line /usr/bin/perl $USER1$/check_disk_snmp.pl -H $HOSTADDRESS$ -s $ARG1$ -d phys -u $ARG2$ -w $ARG3$ -c $ARG4$
abrist
Red Shirt
Post by abrist »
Have you attempted to run the check from the cli?
/usr/bin/perl /usr/local/nagios/check_disk_snmp.pl -H <ip address of remote host> -s nagiosica -d phys -u MB -w 90% -c 99%
tmeto
Post by tmeto »
yes, and.....is the same.
root@xxxxx:/usr/local/nagios/etc/losclientes# /usr/bin/perl /usr/local/nagios/libexec/check_disk_snmp.pl -H 172.16.0.3 -s nagiosica -d phys -u MB -w 90% -c 99%
abrist
Red Shirt
Post by abrist »
I presume that you have configured snmp on the windows server? Do you have any other snmp checks working on the is windows server? Have you looked at using nsclient instead of snmp?
tmeto
Post by tmeto »
I can not use nscliente for this case and we have more on that machine check. It may be the version / windows updates? the machine is very old system......
Post by slansing »
Was NSClient++ not installing for you? What version of windows are you running?
