Event handler executed multiple times
esimonneau
Post by esimonneau »
I've installed a Nagios server (3.2.0) and I need to use a global event handler in order to insert in a database all new events.
I've created a command, associated this command with the parameter global_service_event_handler.
My data are inserted in the database but ...
I've some checks scheduled at a 5 minutes interval, at the first time the check is CRITICAL the global event handler is executed.
But each time the check is CRITICAL (without being OK), the global event handler is launched another time :( .
After reading the documentation many times, it seems to me that the global event handler should be launched only once if the check state doesn't change ?
Does someone have the same problem ?
