I'm trying to add another drive to my nagios monitoring system (with CHECK_NT).
Currently monitors only the drive c: and on a windows server, it works great but once I add more drives (that exist on the same server) I get this error - "Return code of 139 is out of bounds"
I tried to run manually I is getting this error "Segmentation fault"
[root@srv libexec]# ./check_nt -H 192.168.10.1 -p 12489 -s test$ -v USEDDISKSPACE -l c -w 80 -c 50
c:\ - total: 37.27 Gb - used: 25.41 Gb (68%) - free 11.85 Gb (32%) | 'c:\ Used Space'=25.41Gb;29.81;18.63;0.00;37.27
[root@srv libexec]# ./check_nt -H 192.168.10.1 -p 12489 -s test$ -v USEDDISKSPACE -l e -w 80 -c 50
Segmentation fault
working with Centos -5
Nagios Version 3.2.3
Nclient++ 0.3.6 version
Tanks,
Dood.
Re: Return code of 139 is out of bounds
I'd snoop around in your NSClient settings, your syntax looks correct, but NSClient will only broadcast what you configure it to send. (Although it seems like that should work.)
