Re: [Nagios-devel] Possibly typos in checkcommands.cfg
For the first two - I think the numbers were put in such that a decent
default would exist for new users. It is meant to ease them into using
and understanding the config files.
-sg
On Thu, 6 Jun 2002, Jun Kuriyama wrote:
> In sample-config/temlate-object, services.cfg uses some commands
> defined in checkcommands.cfg. But it seems passed argumets of some
> commands are not matched between these files. I think
> checkcommands.cfg is not updated correctly.
> How about this patch?
> Index: sample-config/template-object/checkcommands.cfg.in
> RCS file: /cvsroot/nagios/nagios/sample-config/template-object/checkcommands.cfg.in,v
> retrieving revision 1.2
> diff -u -r1.2 checkcommands.cfg.in
> --- sample-config/template-object/checkcommands.cfg.in 8 Mar 2002 03:38:36 -0000 1.2
> +++ sample-config/template-object/checkcommands.cfg.in 6 Jun 2002 02:16:11 -0000
> @@ -106,7 +106,7 @@
> # 'check_ping' command definition
> define command{
> command_name check_ping
> - command_line $USER1$/check_ping -H $HOSTADDRESS$ -w 10.0,20% -c 100.0,60% -p 5
> + command_line $USER1$/check_ping -H $HOSTADDRESS$ -w $ARG1$ -c $ARG2$ -p 5
> @@ -127,7 +127,7 @@
> # 'check_local_disk' command definition
> define command{
> command_name check_local_disk
> - command_line $USER1$/check_disk -w 20% -c 10% -p $ARG1$
> + command_line $USER1$/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
> @@ -141,7 +141,7 @@
> # 'check_local_procs' command definition
> define command{
> command_name check_local_procs
> - command_line $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
> + command_line $USER1$/check_procs -w $ARG1$ -c $ARG2$
Original poster: sghosh@sghosh.org
