I am making my server a child of my switch.
Having done this I'm still getting an alert on my Host Status page when I take my switch down,
The switch is in a "DOWN" state and the server is in an "UNKNOWN" state.
Shouldn't the server's alerts be suppressed so I only see the switch since it is the parent and it has the problem?
How do I make it so that if the switch does down, nothing gets reported on the server or any of the service that might be on the server?
Here is the cfg files for my server
hosts/testbranch-001.cfg
define host {
host_name testbranch-001
alias testbranch-001
address 10.0.70.180
parents Switch-TestBranch
max_check_attempts 5
check_interval 5
active_checks_enabled 1
passive_checks_enabled 1
check_period 24x7
obsess_over_host 1
check_freshness 1
event_handler_enabled 1
process_perf_data 1
retain_status_information 1
contact_groups novell-admins-Email
notification_interval 120
notification_period 24x7
notification_options d,u,r
notifications_enabled 1
register 1
services/testbranch-001.cfg
service_description PING
is_volatile 0
check_command check_ping!200,20%!500,60%
normal_check_interval 5
retry_check_interval 5
check_period 24x7
parallelize_check 1
obsess_over_service 1
check_freshness 1
flap_detection_enabled 1
process_perf_data 0
active_checks_enabled 0
notification_options w,c,u,r,f
register 1
