I have used Nagios before but is my first time to install it. Everything installed correctly following the Fedora quickstart guide. The first time I was able to logon to nagios with nagiosadmin and was able to see all the panels. after rebooting I can no longer see any panel except the "home" and "documentation" links.
When I try to start nagios in terminal I get this message;
[root@Fedora01 ~]# service nagios start
Starting nagios:This account is currently not available.
done.
Any help would be appreciated.
I also noticed these errors in Apache logs.
[Thu Jan 20 10:53:50 2011] [error] [client 10.4.1.240] (13)Permission denied: exec of '/usr/local/nagios/sbin/tac.cgi' failed, referer: http://10.4.1.240/nagios/side.php
[Thu Jan 20 10:53:50 2011] [error] [client 10.4.1.240] Premature end of script headers: tac.cgi, referer: http://10.4.1.240/nagios/side.php
[Thu Jan 20 10:53:51 2011] [error] [client 10.4.1.240] (13)Permission denied: exec of '/usr/local/nagios/sbin/statusmap.cgi' failed, referer: http://10.4.1.240/nagios/side.php
[Thu Jan 20 10:53:51 2011] [error] [client 10.4.1.240] Premature end of script headers: statusmap.cgi, referer: http://10.4.1.240/nagios/side.php
[Thu Jan 20 10:53:56 2011] [error] [client 10.4.1.240] (13)Permission denied: exec of '/usr/local/nagios/sbin/status.cgi' failed, referer: http://10.4.1.240/nagios/side.php
[Thu Jan 20 10:53:56 2011] [error] [client 10.4.1.240] Premature end of script headers: status.cgi, referer: http://10.4.1.240/nagios/side.php
Re: This account is currently not available
You've got a problem somewhere with permissions. There should be a nagios and nagcmd user on your system. Also check the file permissions/ownership of the files in your nagios/shared directory. The php scripts are complaining because they don't have permission to execute external commands on the system.
