Problem with check_nrpe
TaNabe
Post by TaNabe »
Hi
I'm having a problem with check_nrpe command
I'm running nagios server and client on Red Hat Enterprise Linux 5. Both on different server.
I having a web portal to be monitored so i need an advice
My nagios server is 192.168.201.112 and the client is 192.168.200.209
When i run command ./check_nrpe -H 192.168.200.209 from nagios server it will return message
NRPE v2.12
When i run command ./check_nrpe -H 192.168.200.209 -p 9080 from nagios server it will return message
CHECK_NRPE: Socket timeout after 10 seconds.
When i run command ./check_nrpe -H 192.168.200.209 -p 9080 -t 30 from nagios server it will return message
CHECK_NRPE: Error - Could not complete SSL handshake.
I check my connection using telnet command
telnet 192.168.200.209 9080
Trying 192.168.200.209...
Connected to 192.168.200.209 (192.168.200.209).
Escape character is '^]'.
So the connection should be ok. Is there any setting do i need to check? Please advice
Thanks.
