Default behaviour is still that everything should be possible to urlencode. So
keep it that way.
When zeroing clean_option (=flags for which types of escaping the macro is
allowed to pass), it should actually be set to url encode, not zero.
Signed-off-by: Max Sikström
common/macros.c | 3 ++-
1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/common/macros.c b/common/macros.c
index fa22233..e30634a 100644
--- a/common/macros.c
+++ b/common/macros.c
@@ -407,8 +407,9 @@ int grab_macro_value_r(nagios_macros *mac, char *macro_buffer, char **output, in
if(macro_buffer == NULL || free_macro == NULL)
return ERROR;
+ /* Everything (if not stated otherwise) should be possible to urlencode */
if(clean_options)
- *clean_options = 0;
+ *clean_options = URL_ENCODE_MACRO_CHARS;
* We handle argv and user macros first, since those are by far
1.7.1
Original poster: msikstrom@op5.com
