I am having problem on connect Nagios-Mobility to Nagios Server.
Refer to this link: http://www.nagios-mobility.com/howto.html
Where can I find the web folder in nagiosxi? I totally lost. Please advice.
How to integrate Nagios-Mobility to Nagios Server
Re: How to integrate Nagios-Mobility to Nagios Server
Nagios Core and Nagios XI are very different products. Nagios XI uses session-based authentication, so I don't think you'll be able to do basic authentication in the URL the way that document is describing.
However, the Core interface is still available using basic authentication. It's accessible from http://<yourserver>/nagios
Are you looking for the URL's for Nagios and Nagios XI, or the physical locations of the web files?
Based on the link: http://www.nagios-mobility.com/howto.html
Put the php web file in web folder.
The WebService php file generate in the output an xml.
Where is the php web file it refer to? Where can i find it?
Core webroot directory = /usr/local/nagios/share
I'm guessing that's what it's looking for.
Anyone knows the algorithms or methods used to pull the data from Nagios server to be view in Mobile interface like Nagroid ?
