Re: [Nagios-devel] [PATCH] notifications: Fix
On 12/10/2012 06:27 PM, Jochen Bern wrote:
> On 10.12.2012 16:44, Andreas Ericsson wrote:
>> AFAIR, the original use-case [of first_notification_delay] was
>> to allow operators to react to HARD alerts and acknowledge or
>> fix them before notifications were sent out.
> At least, that's how some organizations *did and do* use it. And some
> probably also add the on-turning-HARD event handler execution to the mix
> of things that hopefully might make notifications unnecessary in the
> last second.
> FWIW, from a rather principles-oriented point of view, the sequence of
> SOFT non-OK --> HARD non-OK --> first notification (with the different
> degrees of visibility these states imply) is as much a part of the
> system of escalations as the part *called* "escalations" is. I wonder
> whether a long-term consolidation of terms and mechanisms might prove
> beneficial.
>> * If delaying the notification causes it to end up in a time where
>> notifications should be sent, it should be sent even if the time of
>> the alert happened during a period when no notifications should have
>> been sent.
>> * If delaying the check causes it to switch to a state which should
>> not result in a notification, no notification should be sent out.
> (That's how escalations *already* behave WRT earlier non- or
> lesser-escalated notifications, isn't it? Hence, The Right Thing To Do
> (tm) in my books.)
AFAICS, yes.
>> * Delaying a notification should not increase its notification_number,
>> and will, as such, affect both regular and escalated notifications.
> *Most definitely* agreed! I know several organizations which would be
> confused to no end if I had to tell them that, under certain
> circumstances, there *just was no* notification #n preceding the #n+1
> they received and try to figure out.
>> * Custom-, downtime-, acknowledgement and flapping notifications will
>> never be delayed (flapping is arguable, but matches current code).
> I am not aware, off the top of my head, of how Acknowledgment and
> Flapping notifications are supposed to behave WRT earlier notifications
> (as in "RECOVERYs are only sent to contacts who also had the PROBLEM
> sent to them"). If such a dependency does/should/will exist, whether or
> not to exempt them from first_notification_delay translates into
> potentially different sets of recipients.
Recovery notifications are sent only to the contacts that supposedly got
the problem notification. It doesn't always work for escalations though;
Only the current tier of escalation will get the recovery notification.
One could argue if that's correct or not, but that's how it is today at
any rate.
> For acknowledgments, sending the notification early (and to the
> *restricted* set of recipients) is likely what the person acknowledging
> the problem *wants* to happen. FWIW, same thing for Downtimes, which are
> technically prophetic acknowledgments. ;-)
> Customs can probably lean both ways, depending on what you use them for.
There's also an extra option for custom notifications, which is to let the
notifyer select how hard the notification should be forced, but I think
that's unnecessary complication. Right now, custom notifications always go
to the primary contacts and the escalated ones aren't considered.
> Flapping ....... I'll have to pass on that. The things I monitor do not
> really flap, and flapping detection is typically disabled.
Flapping is the only real issue, actually. It's a problem, of sorts, but
one where we by empirical evidence should flip a coin to see if we should
notify or not. I think the correct thing to do would be to wait until the
flapping ends and if it comes out in a problem state, add the time the
node was flapping to problem_duration, which is measured against the
notify_delay to see if it's time to notify or not.
That means that a service that starts flapping at 15:05, stops flapping at
15:08 and goes into non-flapping hard critical state should get the three
minutes it spent flapping discounted from the first_notification_delay.
In terms of
...[email truncated]...
Original poster: ae@op5.se
