Return code of 230 is out of bounds
wonka438
Post by wonka438 »
Hi Guys,
I'm just new on nagios I've just installed nagios on a red hat machine.
I used the plugin check_was to detection the websphere.
I'm having errors of (Return code of 230 is out of bounds).
Have you ever got the same error ?
How to solve it ?
:shock: :shock: :shock:
QUAN
mguthrie
Re: Return code of 230 is out of bounds
Post by mguthrie »
Have you tried running the check directly from the command-line? That might give you more useful error output.
