We have a few services which will startup and shutdown at various times. Due to this it is not possible to include them in the nagios configuration upfront.
I would like to periodically poll a DB or a file to enlist the dynamic services and modify the nagios config so that they show up on the Nagios dashboard.
Is there built-in support for such a thing in nagios? If not I would be restarting Nagios everytime the config is changed by a background process.
Yash
Dynamically modifying Nagios config
Re: Dynamically modifying Nagios config
One solution if you know when they will be down is to configure scheduled/recurring downtime for each service. That way at least they will not alert/notify when down. As for actually removing them from the graphical interface, I do not know of a way to do this personally. I will check with some co-workers and get back to you.
Add register 0 to remove them but still keep the config. You can reload (kill -1) the nagios process instead of restarting.
correct.wfournier wrote:Add register 0 to remove them but still keep the config. You can reload (kill -1) the nagios process instead of restarting.
You will only be able to remove the config objects from the frontend, as adding them would require a restart/reload.
