[1381794997] Warning: Return code of 13 for check of host 'foo' was out of bounds.
[1381795002] Warning: Return code of 13 for check of host 'bar' was out of bounds.
[1381795007] Warning: Return code of 13 for check of host 'baz' was out of bounds.
The check_command for hosts is check-host-alive, which is then defined as:
command.cfg:command[check-host-alive]=/usr/lib/nagios/plugins/check_ping -H $HOSTADDRESS$ -w 5000,100% -c 5000,100% -p 1
I know it's supposed to be a matter of permissions, I just can't figure out what exactly. I've checked file ownership, it's nagios:nagios in most places in /var used by this service:
# ls -lR /var/nagios/
/var/nagios/:
total 408
drwxr-xr-x 2 nagios nagios 4096 Oct 1 15:22 archives
-rw-r--r-- 1 nagios nagios 70886 Oct 14 17:02 objects.cache
-rw-r--r-- 1 nagios nagios 70886 Oct 14 17:00 objects.precache
-rw------- 1 nagios nagios 105963 Oct 14 17:02 retention.dat
drwxr-xr-x 2 nagios apache 4096 Oct 14 17:02 rw
drwxr-xr-x 3 nagios nagios 4096 Oct 14 15:42 spool
-rw-rw-r-- 1 nagios nagios 105953 Oct 14 17:06 status.dat
/var/nagios/archives:
total 0
/var/nagios/rw:
total 8
prw-rw---- 1 nagios nagios 0 Oct 14 15:42 nagios.cmd
srw-rw---- 1 nagios nagios 0 Oct 14 17:02 nagios.qh
/var/nagios/spool:
total 8
drwxr-xr-x 2 nagios nagios 4096 Oct 14 17:02 checkresults
/var/nagios/spool/checkresults:
total 0
# ls -lR /var/log/nagios/
/var/log/nagios/:
total 128
-rw-r--r-- 1 nagios nagios 113319 Oct 14 17:06 nagios.log
/var/log/nagios/archives:
total 0
# ps axu | grep nagios
nagios 22521 0.2 0.0 22328 1452 ? S<s 17:10 0:00 /usr/bin/nagios -ud /etc/nagios/nagios.cfg
nagios 22522 0.0 0.0 9708 776 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22523 0.0 0.0 9196 692 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22524 0.0 0.0 9192 688 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22525 0.0 0.0 9196 688 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22526 0.0 0.0 9192 688 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22527 0.0 0.0 9192 688 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22528 0.0 0.0 9192 688 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22529 0.0 0.0 9192 688 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22530 0.0 0.0 9192 688 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22532 0.0 0.0 9192 688 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22533 0.0 0.0 9192 684 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22534 0.0 0.0 9196 692 ? S< 17:10 0:00 /usr/bin/nagios --worker /var/nagios/rw/nagios.qh
nagios 22535 0.0 0.0 21688 708 ? S< 17:10 0:00 /usr/bin/nagios -ud /etc/nagios/nagios.cfg
Any tips or clues? I've looked everywhere, I'm stumped.
