nagios.log (null)
MichaelMoritz
Re: nagios.log (null)
Post by MichaelMoritz »
ls -la /usr/local/nagios/var/nagios.log
-rw-r--r--  1 nagios  nagios  4200 Oct 15 16:41 /usr/local/nagios/var/nagios.log
abrist
Red Shirt
Post by abrist »
lets make sure the nagios group has write permissions:
chmod g+w /usr/local/nagios/var/nagios.log
MichaelMoritz
vc70:/usr/local/nagios/var>ll nagios.log
-rw-rw-r--  1 nagios  nagios  5040 Oct 16 12:17 nagios.log
vc70:/usr/local/nagios/var>sudo /etc/rc.d/nagios restart
Running configuration check...done.
Stopping nagios: .done.
Starting nagios: done.
vc70:/usr/local/nagios/var>tail -4 nagios.log
[1381943945] (null)
[1381943945] (null)
[1381943945] (null)
[1381943945] (null)
Post by slansing »
I know it worked in the past but have not had a need to check the logs for some time. I've done some upgrades since.
What were these upgrades that you did? Did you make any changes to the system such as adding a new logging system?
MichaelMoritz
I upgraded the OS from NetBSD 5.1.2 to 6.1.2 in June 2013. Looking back through my archives I don't have any of the nagios logs prior to the OS upgrade, so it does seem logical that this may have broke then.
I find it interesting though that I can log to syslog but not to nagios.log. Well [timestamp] (null) gets logged.
When I realized logging was broken I tried to upgraded to Nagios 4.0.0 but encountered compile failures. I posted the problem to this forum but have not found a solution. http://support.nagios.com/forum/viewtop ... =7&t=21531 FYI I also tried compiling 4.0.1 with the same failures.
MichaelMoritz
I think if found something. If I add a line to logging.c, removing the printing of the log_time, I get the expected output.
        /* write the buffer to the log file */
        fprintf(fp, "[%lu] %s\n", log_time, buffer);
        fprintf(fp, "here %s\n", buffer);
I'm not a C programmer and do not know what the %lu is but I do notice the following warnings when I compile:
#make nagios
cd ./base && make
gcc -Wall -g -O2 -DHAVE_CONFIG_H -DNSCORE  -c logging.c
logging.c: In function 'write_to_log':
logging.c:235:2: warning: format '%lu' expects type 'long unsigned int', but argument 3 has type 'time_t'
logging.c: In function 'log_debug_info':
logging.c:558:2: warning: format '%lu' expects type 'long unsigned int', but argument 3 has type 'time_t'
logging.c:558:2: warning: format '%06lu' expects type 'long unsigned int', but argument 4 has type 'suseconds_t'
gcc -Wall -g -O2 -DHAVE_CONFIG_H -DNSCORE -o nagios nagios.c broker.o nebmods.o ../common/shared.o checks.o config.o commands.o events.o flapping.o logging.o macros-base.o netutils.o notifications.o sehandlers.o skiplist.o utils.o retention-base.o xretention-base.o comments-base.o xcomments-base.o objects-base.o xobjects-base.o statusdata-base.o xstatusdata-base.o perfdata-base.o xperfdata-base.o downtime-base.o xdowntime-base.o    -Wl,-export-dynamic   -lm  -lpthread
MichaelMoritz
google tells me that NetBSD 6 time_t is 64 bit and %lu is 32. I changed the print to %llu and logging is working.
        fprintf(fp, "[%llu] %s\n", log_time, buffer);
I'm sure this is not the *right* way to do it for portability, but hopefully this can put someone knowledgeable in C on the right track. :-)
abrist
Red Shirt
Post by abrist »
could you submit a bug report to http://tracker.nagios.org with your solution?
MichaelMoritz
Done, ID 512.
Thanks for your help in troubleshooting.
Mike
abrist
Red Shirt
Post by abrist »
I also opened an internal bug report as well. It should catch Eric's attention. I presume the proper place to follow the bug will now be on tracker.
