I recently upgraded to Nagios 4.0.1 from Nagios 3.5.0 and started getting service check output as(No output on stdout) stderr:[ i.e., plugin_output = (No output on stdout) stderr:]. And, I also started observing that there are lot of zombie process getting created for Perl and sometimes for Nagios when you reload not if you restart. And, also there is a loss of performance data being updated(integrated pnp4nagios), I can see the following error in the Nagios log file:
[1381928212] wproc: SERVICE PERFDATA job 13 from worker Core Worker 8077 is a non-check helper but exited with return code 2
[1381928212] wproc: command: /usr/bin/perl /usr/local/pnp4nagios/libexec/process_perfdata.pl
[1381928212] wproc: early_timeout=0; exited_ok=1; wait_status=512; error_code=0;
[1381928212] Worker 8077: Unknown jobtype: 10
[1381928212] wproc: Unknown job type: 10
I think the worker is not capable of handling perl related code to return back to Nagios core or parent (FYI I am not using embedded perl). Any help is much appreciated.
Thanks for your time.
Note: The return status from the plug-in is OK but it is unable to read the output from Standard Output or Standard Error of the Shell (it's intermittent).
Regards,
Babu Dhinakaran S
Nagios 3.x to 4.x upgrade issue(No output on stdout) stderr:
- -fno-stack-protector
Re: Nagios 3.x to 4.x upgrade issue(No output on stdout) std
It is not an issue with perl, but actually something to do with how core is handling the data. There is already a tracker issue posted for this bug. As there is nothing presently we can do I am going to lock this. Please feel free to add comments to the tracker issue found below: http://tracker.nagios.org/view.php?id=484
